C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] LS7 heads on LS3 427 stroker
Old 09-13-2010, 02:57 AM
heavychevy357
heavychevy357's Avatar
Default LS7 heads on LS3 427 stroker
hey guys i was wondering which flowed better & which would be better for an LS3 427 stroker build. heard the LS7 heads were awsome on the ZO6 & wasnt worth replacing & wondered if they would fit on the LS3 427 shortblock like Texas Speed & Scoggin Dickey sell. would a cam made for an LS7 work in that engine also? what about intake would i need an LS7 intake to match up to the LS7 heads ? are AFR & TFS heads better than LS7 heads?
Old 09-13-2010, 03:09 AM
kumar75150
kumar75150's Avatar
what's the bore on the ls3 427?
ive read you need >= 4.1" bore for the ls7 heads
edit: the bore is 4.07
1st google result: http://www.ls1tech.com/forums/genera...-bolt-ls3.html
Old 09-13-2010, 10:04 AM
heavychevy357
alright thanks kumar. does anybody know if a cam made for an LS7 would work in an LS3 block?
Old 09-13-2010, 12:16 PM
obzidian
obzidian's Avatar
St. Jude Donor '09
Though they are both rectangular ports, they both flow quite differently. I would spec a cam for the heads ON THE MOTOR.
To LS7 heads on LS3 427 stroker
Quick Reply: [Z06] LS7 heads on LS3 427 stroker
