[Z06] Z06 OEM and Aftermarket Parts Weight List
#482
I've had some extra time on my hands (shocker) so I'm working on adding a weight calculator for the Z06 weights list.
I'm working on finishing it up right now but the calculator will allow you to select your year Z06/ZR1 and also the modifications you have to get a relatively accurate weight of your car!! I used the most updated Z06/ZR1 weights list available so it will only be limited to what was on that list.
I'm also going to add a part that will let you input your cars horsepower to calculate the power/weight ratio.
When it's done we'll have to figure out a way to upload the calculator onto the current weights list on Dropbox but I don't think it'll be too bad.
But I have the updated spreadsheet with the calculator tab so you can theoretically "weigh" car with your aftermarket parts. I included it in pounds and kilograms. Also included a LB/HP calculator.
Now the question is... how do I get my document to upload into the Dropbox section for people to check it out and see how it works?
#483
Can't believe I forgot to post this.
#484
https://drive.google.com/file/d/0BxK...ew?usp=sharing
Does this work?
EDIT: Yes it works. You are able to download it right onto your computer OR use Google Docs to view it.
Does this work?
#485
Does this work?
Does this work?
#486
#488
Thanks for a really cool product! I'm sure you put in a lot of time to make this spreadsheet work so well.
At first, Google Drive said that it was too big to virus check and wouldn't load. So I downloaded it anyway. It opened and ran fine on my Win10 machine using Excel 2010.
Can we post, or PM, additions and corrections?
John
#489
I'm surprised there is no weight listed for American Racing 1 7/8 headers with catted x-pipe by now. It says OEM manifolds, mid section, and cats weigh 74.5lbs. Down below that vs other systems (if you do the math) it appears the oem setup weighs 65.6lbs. Hmmm? I'm currently having AR 2" headers with catted x pipe installed and am trying to add up how much weight I'm losing with other mods.
thanks, Jesse
thanks, Jesse
#490
thanks, Jesse
thanks, Jesse
#492
2013 oem manifolds, mid pipes with cats, and x pipe with 2nd set of cats weighed in at 78lbs on home digital scale. It's odd how it says the oem setup is 74lbs but then compared to a kooks or lg setup a few rows down that weighs 55lbs it says that setup is -10 lbs from oem.?
Anybody know the weight of 2" AR headers and catted x pipe?
#494
American Racing 2" Long Tubes with Catted Mid Pipe - Ceramic Coated - 53.6 LBS
This is a 2012 ZR1 / Z06 System - 3" Mid Pipes - MFG Jan 2018
#495
Exedy twin disc with 19k miles on it: 35.42 lbs
Tilton triple carbon clutch with a few hundred miles on it: 16.0 lbs
ATI 10% underdrive pulley: 8.44 lbs
Stock motor mounts: 7.45 lbs
Vulcan motor mounts (street): 3.36
Heat shield between the mufflers and trunk, with fasteners: 1.86 lbs
Pfadt transmission mounts: 3.0 lbs
#497
Wondering what some of the previous guys are,
Kooks 1 7/8 WITH cats are listed at same weight aprox as ARH 1 7/8 without cats, can this be true?
Would be good to se 2" numbers as well. Im going with headers, but for me weight is critical, and I will run cats for emissions/inspection, is it really true the kooks are that much lighter?
#498
Brodix BR7 head full assembled weigh about 29 pounds (each) which I think is about 4-5 pounds heavier than stock.
#499
Interesting the brodix are heavier, Im considering wcch stage 2 brodix, hate adding weight though.
Anyone with 2" arh or kooks that can chime in on weight? with/without cats, any data would help
