Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C6 Corvette, 2005 - 2013 > C6 Corvette ZR1 & Z06
Reload this Page >
[Z06] Nitto NT05 vs. Mickey Thompson ET Street Radial II
C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Advertisement
Old 12-05-2010, 03:54 PM
ajbarbato15
CF Senior Member
ajbarbato15's Avatar
Default Nitto NT05 vs. Mickey Thompson ET Street Radial II
Looking for the best possible wheel/tire setup for high horsepower (610-630 to the wheels) on the street. I thought I had made up my mind on the NT05 on my factory wheels. Then I ran across these ET Street Radial II's that I could get in a 345/35/18. I could make this work by getting 18" Z06 reproduction rear wheels. Which setup do you guys think is better for the street? Or do you have any other suggestions??
Anthony
ajbarbato15 is offline
Old 12-05-2010, 05:40 PM
6Speeder
CF Senior Member
6Speeder's Avatar
Another choice to consider: Hoosier drag radials sized 335/30-18. They will give you about a 5% gearing advantage compared to the taller tires and are pretty sticky.
6Speeder is offline
Old 12-05-2010, 05:51 PM
obzidian
CF Senior Member
obzidian's Avatar
St. Jude Donor '09
Well, both the Hoosiers and the MT's are true drag radials so the NT05 should even be considered an alternative when comparing those tires. Now, NT05R is a great drag radial and will perform very well vs either the MT's or the Hoosiers. Also, I would look into a set of M&H... They stick something serious!
obzidian is offline
Old 12-05-2010, 07:48 PM
ajbarbato15
CF Senior Member
Thank you guys for the comments. I did forget to mention one thing. The setup that I am looking for is for street only. I may bring the car to the strip a few times, but thats it. I honestly think I am just getting overwhelmed with tire/wheel choices. My build will be pushing 630 rear wheel horsepower. What is the best wheel/tire choice for me????
Thanks!
Anthony
Old 12-06-2010, 04:08 AM
MPM IV
CF Senior Member
MPM IV's Avatar
I would try the NT05R first. I'm at 600rwhp and can go wide open in second without spinning on Hoosier R6 road race tires. Based on that I'd think a drag radial on your stock wheels would hold the power.
MPM IV is online now
Old 12-06-2010, 10:30 AM
ajbarbato15
CF Senior Member
Do you think the NT05R would hold up well on the street? I always thought the NT05R was more for track only use, and just NT05 was for street...
Old 12-06-2010, 04:47 PM
MPM IV
CF Senior Member
MPM IV's Avatar
As well as any tire that will hold 610-630hp. It's got a treadwear rating of 00, so it won't be a high mileage tire. Since you also mentioned the ET street I didn't realize than was important to you.
If you want something that will last longer and hook better than a true street tire look into the R compound tires with a treadwear rating between 100 and 200.
I've driven on drag radials and road race tires for many years. My advice is stay out of rain and expect them to throw everything on the road on your car.
Old 12-06-2010, 05:31 PM
obzidian
CF Senior Member
obzidian's Avatar
St. Jude Donor '09
Do you daily drive the car? Meaning, those the car see any stop and go, wet roads?
obzidian is offline
Old 12-06-2010, 05:40 PM
lane_change
CF Senior Member
lane_change's Avatar
I daily drive mine, but I am trying to choose tires for a second set of wheels....leaning towards the Hoosier DR's due to the weight difference between them and the MT's. The NT05R's are on backorder everywhere, so I didn't even factor them into my decision making process. Now the debate is whether or not to buy 17's or 18's, or whether or not to buy someone's used drag pack (Rob G, RCC, or Ratt G) since all are currently selling decent drag setups.
lane_change is online now
Old 12-06-2010, 06:10 PM
ajbarbato15
CF Senior Member
I do daily drive the car, so it will see all of the above.
Old 12-06-2010, 06:53 PM
morris
CF Senior Member
The problem I see with this is that the track tires you want to run will probably never get up to the correct operating temps on the street so you might not get the extra traction you are looking for any way, but hey I'm not a tire engineer
morris is offline
Old 12-07-2010, 05:08 AM
csilvers1984
CF Senior Member
With my exp with drs on the street I prefer a taller tire. My reasoning comes from the ability to tame the car down a tad from a dig. I went from a 26 to a 28 on my whipple cobra and it was a great move! Now with my c5z I pulled a 1.54 at the track on a 305/35/18 mt dr but on the street the tire is useless from a dig in 1st (484/439 and 4.10s)
csilvers1984 is offline
Old 12-07-2010, 07:41 AM
0The Speed Depot
Former Vendor
You may also want to consider the Nitto NT555R, this is more of a street tire compared to the NT05R. It is available in a 335/30/18.
The Speed Depot is offline
Old 12-07-2010, 08:31 AM
Black_Mamba
CF Senior Member
Black_Mamba's Avatar
I have tried most. So here goes my take on it. Some facts and some opinions mixed make it interesting IMO. I make about 580 all motor then spray say a 100-150 shot, sometimes 200hp shots. Anyway I will speak in terms of whp so anything above is 580 + shot.
The MT2 will require a fair burnout to hook better on the street it's kind of a hard tire but will work better than most in rain. Will hook NA on 2nd, give it a shot to 700 and it spins if I did not do a GOOD burnout. At 772rwhp it was spin city from a roll in 2nd. With 0 camber at the rear I believe this will be a killer street setup.
The BFG will hook with less temp (just a bit of a haze) in them and slow, say 40mph no standing water, on the rain is not so scary. Cold they DEAD hooked the 700rwhp every time. These hook NA in 1st gear if hot on the street. Always used these on stock suspension settings.
The MH is one mean mean hook but also scare me ****less on rain. I want to try and see if they hook the 830rwhp in a 2nd gear roll. Unlikely . Maybe these will dead hook on the 772rwhp setup.
The Hoosier R6 is the best tire ever hehehe as I am more of a road racer but it is not really a drag radial. And I believe it will not dead hook the 700whp, I will try that in a couple of days in Mexico City. They hook the all motor setup well on track suspension settings.
NEXT... Hoosier DR slick rattg style
Black_Mamba is offline
Old 12-07-2010, 09:40 AM
ajbarbato15
CF Senior Member
Damn. No offense to any of you that have posted, but I think I am more confused now than I was before...
Old 12-07-2010, 10:18 AM
lane_change
CF Senior Member
The BFG description seemed pretty interesting since I have never even considered them as an option. How is the weight on those tires? I have heard nothing but good things about the Hoosiers, they're light, sticky, and come in the right sizes...but I guess I need to compare the BFG's now. The only reason I would not want to go with a taller rear tire as mentioned above, is because I want to be in 4th gear when I cross the 1/4. Not sure how much an extra 1.3" of tire will effect the gearing, it may help off the line if you need to slow the rotation of the tires down, but I remember when the car was stock hitting the 1/4 mile right at the 3-4 shift point was annoying. Now, I am in 4th well before the 1/4, but with a taller tire I could end up back where I was. Again, not sure if a taller tire would push 3rd gear up to 132mph, but if it did, I would not go that route.
Old 12-07-2010, 02:02 PM
csilvers1984
CF Senior Member
I would only run a taller tire on the street! No way would I run it at the track unless your running out of gear. On motor I cross the traps around 6800-7k in 4th at 131 so only if I was going to spray would I run a 28in so I didn't have to shift to 5th.
Now the street is a completly diff story,yea a car might dead hook from a roll but a dig is iffy. That's when I prefer a little taller tire. But againe power/gear I the reasoning for my op.
Old 12-07-2010, 03:25 PM
Frans96ss
Supporting Vendor
Frans96ss's Avatar
St. Jude Donor '09
NT05R is a very nice tire. They work well on a couple 600rwhp cars we have done.
Frans96ss is offline
Old 12-07-2010, 09:26 PM
ajbarbato15
CF Senior Member
Well Fran you would be the one to give me the best answer, as you are the one doing the build. Do you think the NT05R would be my best bet? I have been looking at MT ET Streets cause they look absolutely killer, like these on FNQWK's car...
Do you think something like this would work?
Anthony
Old 12-17-2010, 05:28 PM
Geared
CF Senior Member
Support Corvetteforum!
Geared's Avatar
is that an 18? or 19? in the above picture
Geared is offline
Quick Reply: [Z06] Nitto NT05 vs. Mickey Thompson ET Street Radial II
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
