C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Changed the battery..now the windows don't roll up
Old 12-09-2010, 06:51 PM
pirate#3
pirate#3's Avatar
Default Changed the battery..now the windows don't roll up
when I shut the door....
Old 12-09-2010, 06:56 PM
spartanc6z06
spartanc6z06's Avatar
SAME!! Except mine wont roll up all the way after shutting the door because i had to boost my battery since it died. Anybody?
Old 12-09-2010, 07:00 PM
3LZZ06
_"SCOTT"_
Support Corvetteforum!
3LZZ06's Avatar
You have to re-index your windows. You'll find it in your manual but here's a description of what to do...
Get in and close the door, start the car or use the accessory on. Roll your window all the way up and release the button then pull the button up again and hold for a few seconds. Do the same with the passenger window and your all set.
The windows will index just like new...
PS. check back when you're done.
Old 12-09-2010, 08:04 PM
Rosspbig
Rosspbig's Avatar
This works. Same thing happened to me when I changed my battery.
Old 12-10-2010, 02:11 PM
letsrollmike
letsrollmike's Avatar
Be a real man. Just roll with the windows down 24/7. Even in the winter/rain. I would be like "Man that guy is hardcore", if i seen you.
Old 12-10-2010, 02:22 PM
JBHunter
JBHunter's Avatar
AGAIN this Forum provides excellent advice from those that know to help us all out...
Thank you everybody that helps everyone else out...
What a great place to be a member of!!!
Old 12-10-2010, 02:34 PM
jeffreystar
jeffreystar's Avatar
This information is also in your owners manual Re-Indexing.
I agree, great forum.
Old 12-10-2010, 06:45 PM
z06clif
z06clif's Avatar
Page 217
Clif
Old 12-10-2010, 07:56 PM
paisa427
paisa427's Avatar
From what i was told by the corvette mechanic, the z06 has 28 different computers, and once the vehicle hits under 9volts of battery they begin to shut down. starting with the windows and going from least important (power seats) to most important(engine and ecu running), and have to be manually reprogrammed.
Old 12-11-2010, 09:12 AM
pirate#3
pirate#3's Avatar
X2. Thanks for the quick and helpful responses!
Old 12-11-2010, 10:02 AM
blkvette1
blkvette1's Avatar
Well, a comment from the "average" GM Corvette mechanic is not worth ****.
Are you telling me that if I change batteries, I have to go through manually programming 28 computers in my Z06. What is that guy smoking?
1. Install the new battery
2. Re-index the windows
3. Roll through the DIC settings
4. Reset the stereo "favorites"
5. Rev to 3,000 and let the clutch out
Old 12-11-2010, 12:16 PM
MasterDave
Moderator
MasterDave's Avatar
Now THAT'S funny!
Old 12-11-2010, 04:02 PM
dmuellenberg
dmuellenberg's Avatar
I have removed the battery in my Z06 every winter for the past 5 years and the only thing I have to 'reprogram' when I put the battery back in is to reindex the windows. Even the presets on the radio are still there.
Old 01-24-2011, 01:41 PM
08AtomicO
08AtomicO's Avatar
i was freaked out today when my windows didn't go all the way up. A quick search here solved it. Thanks for the help
Old 01-24-2011, 01:50 PM
ockie
ockie's Avatar
Ask the mechanic what he is smoking, I'm sure some of us would like to avoid the "cheap stuff"
Old 01-24-2011, 01:51 PM
jeffreystar
Rtfm?
Old 01-24-2011, 05:36 PM
BLACK BEAST Z06
BLACK BEAST Z06's Avatar
good info !!!!!
thanx
To Changed the battery..now the windows don't roll up
Old 01-24-2011, 06:30 PM
z06clif
z06clif's Avatar
Re-index the windows......p217 in the manual...............happened to us all
clif
Old 03-17-2012, 10:26 PM
fntm309
7th Gear
fntm309's Avatar
Default Window Re-indexing
Verbatum from the GM gods;
Power Window Initialize
After a power reconnect such as battery replacement,
the window index‐up feature will not function until the
system is initialized.
Once power is restored:
1. Close the door.
2. Raise the window and hold the switch up for
three seconds after the window is closed.
3. Release the switch, then hold the switch up again
for three seconds and release.
Old 03-17-2012, 10:33 PM
fntm309
7th Gear
fntm309's Avatar
Default Re-Index Windows
Fired up my ZR1 today. Temp Control said it was 7 degrees outside... when it was 75. AC would not work (car thought it was too cold outside)
After a few hrs I rebooted the car ( battery disconnect)
1) Temp came back to 75 as expected.
2) AC worked perfectly
3) Windows wouldn't roll up.
Found the solution here. Easier than opening the C6 library of knowledge. Thanks to you all!
Quick Reply: [Z06] Changed the battery..now the windows don't roll up
