C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Wheel spacers??
Old 10-22-2013, 11:12 AM
  #101
VictoryRedZ06
VictoryRedZ06's Avatar
Originally Posted by NachosZO6
Victory, what brand/size of studs did you go with? You went with a 3/8" up front and 1/4" out back right?
DRM brotha! Yup 1/4 inch in back 3/8 up front
Old 11-28-2013, 09:58 AM
  #102
BTR_FTW
BTR_FTW's Avatar
bump for more pics
Old 11-28-2013, 04:07 PM
  #103
A Man and his Vette
A Man and his Vette's Avatar
[/URL][/IMG]
[/URL][/IMG]
Here are some pics using 1/4 inch spacers all the way around on stock tires. I think it does a nice job of bringing the tires near flush with the fender, more so on the back than the front. I think it will look great when I go with 285/345 sizing this spring.
Old 11-28-2013, 04:20 PM
  #104
A Man and his Vette
One more try with the photos...
Old 11-29-2013, 12:44 AM
  #105
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Originally Posted by A Man and his Vette
[/URL][/IMG]
[/URL][/IMG]
That does look nice...did you change the studs?
Old 11-29-2013, 02:17 AM
  #106
A Man and his Vette
Nope...but I did have to go to extended tip lug-nuts.
Old 12-10-2013, 04:53 PM
  #107
BTR_FTW
BTR_FTW's Avatar
what size tires in the rear?
Old 12-10-2013, 09:58 PM
  #108
A Man and his Vette
stock....325/30/19
Old 12-11-2013, 10:09 AM
  #109
NachosZO6
NachosZO6's Avatar
Did/have you had any issues with those extended tip lugs nuts? I just spoke to a couple of people and they highly recommended against it, but haven't tried it, so I thought I'd ask someone who has. I currently have 1/4" out back with stock studs and nuts and want to do 3/8 up front.
Old 12-11-2013, 11:33 AM
  #110
A Man and his Vette
I have not had any issues. They were put on and torqued to spec (I think 110 lbs). Occasional checks with my torque wrench shows they have stayed on nice and tight. Why are people recommending against them?
Old 12-11-2013, 12:24 PM
  #111
NachosZO6
NachosZO6's Avatar
They're telling me they will back out or that the extended tip won't go into wheel hole and will damage the wheel if I force it. Mine haven't loosened up to this day and it's been a few months and I've driven it hard. And those are the standard lug nuts. ETs can only help.
Old 12-21-2013, 10:35 AM
  #112
Mikael Smed
Mikael Smed's Avatar
So OEM on my C6 ZO6 is 9.5x18 +40mm front and 12x19 +59mm rear. I was thinking of getting some new Forgestar CF5V or F14 wheels in gloss black; 10x19 front and 12x19 rear. Should I order them 10x19 +30mm front and 12x19 +53 rear? I would be buying 295/30ZR19 and 345/30ZR19 MPSS tires to go with them. What are your thoughts?
Old 12-21-2013, 11:09 AM
  #113
Mikael Smed
The F14 SDC wheels look sick and can come in 19x10 +30 and 19x12 +55 Max Offsets. I'm thinking +30 on fronts and +53 on the rears.
Old 11-07-2014, 03:47 PM
  #114
usmcpony
usmcpony's Avatar
I have 19/20 cup wheels with 285/345 invos. What size spacers would be recommended?
Old 02-04-2016, 04:54 PM
  #115
Bfayard
Bfayard's Avatar
Any pictures of the spacers on your car. The links provided are not working now. Curious about how they look
Old 07-22-2016, 12:29 PM
  #116
nsx_ed
nsx_ed's Avatar
Im thinking about going 15mm in the front and 10mm in the rear on my stock C6Z wheels. Anything i should be looking out for? Thoughts?
Old 10-29-2016, 10:39 PM
  #117
Jcbarr25
Jcbarr25's Avatar
Did you ever install this size adapters you are talking about? I think 15mm up front might be perfect with flushing the wheel. but in the rear it might be too much. looking to do some spacers myself too
Old 11-06-2020, 09:39 AM
  #118
dragnby
dragnby's Avatar
OEM C7 Z06 wheels on my GS. 20mm spacers up front and 5mm spacer in rear. 275/30/19 front and 345/25/20 rear
Old 11-07-2020, 04:07 PM
  #119
OBSean
OBSean's Avatar
I just took off my spacers with stock wheels put on a set of Forgestar F14 wheels I have a set of 1/2 in for the rear and 1/4 for the front.
Quick Reply: [Z06] Wheel spacers??
