C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] My Active Handling problem fixed
Old 04-21-2012, 08:09 PM
billcar9999
billcar9999's Avatar
I had this problem in an 06 Convertible. I went through the connector fixes, wiring replacement and everything else the dealer wanted to try. After two lane departures, I'd had enough.
Ultimately, it was the brake control module. It was a problem with this module communicating with the other modules. It was captured with a data collection box that the dealer installed. You'll only get the basic codes without this data collection box. I posted the blow by blow a long time ago.
Old 04-30-2014, 09:49 AM
myfunz
myfunz's Avatar
Old 07-31-2016, 12:54 PM
VETFEVER
Support Corvetteforum!
VETFEVER's Avatar
Bump
vetfever
corrado (08-12-2016)
Old 08-14-2016, 12:41 PM
franman69
franman69's Avatar
Originally Posted by QwikC
Recall:
http://nhthqnwws112.odi.nhtsa.dot.go...056-31583P.pdf
:: LINK to DIY procedure, click here.
SUGGESTION: When performing a DIY, visit dealer in order to record and/or substantiate the fix as well as clear any relative/outstanding codes.
I know this is an old thread, but for those of us who are just dealing with this (as the SERVICE AH SERVICE TC message starts popping up), I want to thank all who contributed specifically NVL_AV8R's Photo bucket with photos showing the actual connector.. not sure if I would have found it without those photos.... Complete, connector clean, exercised and Comb installed! Hopefully that's the end of this issue.
Old 07-19-2017, 09:06 PM
Vinsvette10
4th Gear
Vinsvette10's Avatar
Default C6 grand sport active handling light
Out of no where my active handling light came on, but crazy to me is the car stopped running right...
Quick Reply: [Z06] My Active Handling problem fixed
