C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Purchase a 2007 Z06 vs a 2008 Z06 ??
Old 02-23-2011, 01:00 AM
toplessv
toplessv's Avatar
Default Purchase a 2007 Z06 vs a 2008 Z06 ??
Looking for opinions on buying a 2007 Z06 vs a 2008 Z06.
I am concerned about the needle bearing problem on the 2007 and also understand the 2008 has a different transmission.
Have found a low mileage Ron Fellows car but am concerned about the needle bearing and broken rocker problem.
All comments appreciated.
Old 02-23-2011, 01:15 AM
NORTY
NORTY's Avatar
Nov 2006 to May 2007 are the suspect build dates. You may need to get in touch with the museum to find out the engine build date.
For instance: My engine was built 1 month before the car was built.
Old 02-23-2011, 09:17 AM
GMuffley
GMuffley's Avatar
I would have no concerns about the 07. Take the best priced vehicle.
Old 02-23-2011, 09:25 AM
MarkRx
MarkRx's Avatar
where did you get that info from? if that's the case then i need to go back and correct about 100 posts, including the sticky in the rocker arm thread, inform GM their roof recall notice is incorrect and run to change my rockers asap! :LOL: my 07 (build date 12/06) has 0 issues. no roof recall, and no bad rockers. rocker issue was generally 01/07-07/07 the 07/07 engine build date was actually in a 2008 MY Z06.
to the OP: all ron fellows cars are suspected to have been built with potentially faulty rockers. not if, but when. RFZ's are nice "numbered" cars, but when you drop a valve and lunch the motor, you'll wish you spent the extra $$ on a 2010 Z06 in arctic white with a factory warranty. yes the 07's have a 5yr/100k powertrain due to expire any time now unless you extended it (GMPP) or are lucky to find an RFZ sitting in a museum still under MSO with 3 miles on it.
Old 02-23-2011, 10:29 AM
CanadianVetster
CanadianVetster's Avatar
I believe that the bearing issue is not all that expensive to replace...
just add that into the price considerations and car conditions.
Old 02-23-2011, 11:22 AM
ZZZZZR1
ZZZZZR1's Avatar
Needle bearing issue, front and center:
http://forums.corvetteforum.com/c6-z...ngs-issue.html
Old 02-23-2011, 11:37 AM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,910 Likes on 5,325 Posts
Go with the newer car. The transmission in the 08 is easier to shift and there may be some of the 3/36 bumper to bumper warranty left. Then if you want you can get a GMPP Major Guard service plan. Once the 3/36 runs out you can't get the Major Guard. The 3/36 on my car runs out in two days so I purchased a 7 year Major Guard plan for about $350/year. The way I use my car I know that I will spend more than that on wheel bearings and tie rod ends over the next 4 years so it seemed like a good deal for me.
Bill
Old 02-23-2011, 11:41 AM
FrankTank
FrankTank's Avatar
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
I just picked up a used 07 last year..no issues whatsoever and it has about 18k miles on it. I Love the car.
That said though, I would go with the newest you can afford which would be the 08. I just could not stretch the extra cash for the 08..as others have mentioned it has a newer Trans..you'll have more warranty left on it too. Also, the 3lZ package started in 08 as an option.
Old 02-23-2011, 12:55 PM
TheKomoman
Support Corvetteforum!
TheKomoman's Avatar
St Jude Donor '13
Assuming the price difference wasn't enough to sway me I'd take the '08(both great cars and I wouldn't hesitate buying an 07 at the right price). I have an '06 convertible and an '08Z and the difference in the shifting is ENORMOUS. The '06 is stiff and notchy and can feel a little vague when you're shifting hard. The '08 is silky smooth by comparison. I put a shifter in my '06 to help the feel some but I haven't bothered on the '08.
Old 02-23-2011, 06:03 PM
QUAKEJAKE
QUAKEJAKE's Avatar
My 07Z circa 01/07 has 24K trouble free miles. With regard to the 08transmission I've driven the "improved" late model and if thats the only reason to buy a newer model it's not noticable enough to pay extra $ for it.
Old 02-24-2011, 12:42 AM
96LT1Conn
96LT1Conn's Avatar
I asked myself the same question last year before buying my 08Z. I figured, why take the chance with an 07 and went with an 08. With an 08 at least you get rid of the wretched gray console for a CF one too. No regrets whatsoever on my part.
Old 02-24-2011, 10:18 AM
MarkRx
MarkRx's Avatar
or buy the 07 and spend $300 on a new 08 carbon fiber console.
Old 02-24-2011, 01:13 PM
Sleazy Rider
Sleazy Rider's Avatar
I looked at 07's and 08's and decided on the 07' Le Mans Blue over the Jet SISSY Blue. I was leaning on the 08' because of the trans/rack/console/rockers, but really liked the 07' blue better.
Old 02-24-2011, 08:43 PM
Jimmy Z
Jimmy Z's Avatar
Bill
plus a nicer interior
Old 02-24-2011, 10:40 PM
Magneson
Magneson's Avatar
JSB > Le Mans Blue
Old 02-25-2011, 02:13 PM
QUAKEJAKE
QUAKEJAKE's Avatar
Originally Posted by Magneson
JSB > Le Mans Blue
My wife said to JSB. Said it was to "Girly"
Old 02-25-2011, 05:11 PM
Sleazy Rider
Old 02-25-2011, 08:30 PM
3LZZ06
_"SCOTT"_
3LZZ06's Avatar
Excellent choice.
LMB is the nicest color ever offered in many peoples eyes, including mine.
CONGRATS!!!
Old 02-25-2011, 09:00 PM
Rock36
Rock36's Avatar
I have an 07 and absolutely no issues, but the car was delivered in Oct 06 so I think I missed the needle bearing problem, and again no problems.
Oh and LMB is awesome. I love it.
To Purchase a 2007 Z06 vs a 2008 Z06 ??
Quick Reply: [Z06] Purchase a 2007 Z06 vs a 2008 Z06 ??
