[Z06] PCM/ECU questions.
Find a different tuner if they don't know how to deal with that. It is beyond easy.
Just do the proper scaling.
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
You c an not swap to a different year ECM.
So I know I'm bringing this back to life, but I wanted to get some input. My 08 is about to tuned with a blower and I'm hearing that my ECM is limited in terms of fuel injector size via the table sizes in the ECM and that the stock MAF on the 08 is already maxed out on a H/C/I setup so I need to get something bigger. On the fuel injectors side, do people regularly just re-scale the factory tables to account for larger injectors and just lose some adjustability, do they re-pin and swap in a newer ECU or do they go aftermarket all together? Thanks for help or links to threads with info in them.
As stated, you can do some injector scaling via a few different methods.
For anyone interested, I have close to 200 E40, E38, and E67 ECMs and can usually unlock your LOCKED or BRICKED ecm
call anytime if you need a spare ECM or yours becomes unusable.
I got the GOODS!
Chuck CoW
If your tuner is using a MAF tune on a FI build along with struggling with tuning for bigger injectors when it's been done many times over I think you might start the hunt for a new tuner.
He didn't say I couldn't go another route, but we responding to a recent car I was present for tuning on that was a 2011 z06 on the same blower setup. It put down 830rwhp on the factory MAF and had larger tables to use with the bigger Injectors. I was simply getting outside counsel for whether going SD was the right way to or whether there was an advisable way to stay MAF and scale my smaller injector tables. Thanks for everyone's input. Looks like I may be pursuing SD tuning with someone else who isn't remote for the setup.
As always I appreciate the knowledge on here. Looks like I might go Speed Density then. I was worried about weather changes and it running well on SD tuning.
Be sure whatever tuner you select for your SD based tune takes their time on the tuning. VE tables are hard coded and to make changes you'd need your own HPTuners software and interface. MAF based tunes adjust themselves based on the MAF reading and use the VE tables as a fall back. This is just another reason to make sure your tuner is local to you too if you need any touch ups.
Stock maf is fine for 1200+
Stock ecu is fine for 1200+
Sébast19X (01-27-2018)
I ran maf at 1200+
Jody runs a maf at 1000+
Maf limits depend on size of tube it is in. A stock card style maf will make 1300+ in a 4" tube. You can go to a 4.25 or larger if you need more.
Now if you stick it in a 3" tube, yah you may run out of maf range.
Indepth (04-03-2017)
Ah, so you're saying this is dependent on the intake's diameter surrounding the MAF - that makes sense to me then.
Originally Posted by Unreal
I ran maf at 1200+
#33
Just 1/2 the IFR and double stoich. Don't even really lose any adjust ability in the tuning.
There are some other advantages to a newer ECU, but for what you want, wouldn't deal with the hassle.
I have a 2009+ ecu sitting in garage waiting to go in, but haven't found the will power to do it just to read boost past 2.5 bar.
#34
Thanks again for all the info. Unreal, if you want to discuss on the phone, I could use some reassurance on this before I pick a direction (SD or MAF tuning).
#35
Injector flow rate.
So if you have 100lb injectors you put them in as 50s, then double a few tables, done. No need to mess with ecu swaps, etc.
SD vs maf depends on your car/tuning. Still a fan of hybrid. Ran both. Like factory, SD works better at low RPM, taming out transistions, etc, but maf works great from 3500+ when air is flowing good. Do both like the factory.
If I had to choose only 1, I would do SD. Only reason I'm SD only is I like the upper pipe with no maf, so I don't even have a maf on my car.
#36
IFR stands for? Sorry I'm getting my education today. So it sounds like you can make these changes to offset and then use the tables as is, or is there a lot of background work to do in order to tune after that?
https://www.hptuners.com/forum/showt...2-Acronym-List
IFR-Injector Flow Rate
#37
Another real-world example of why it is good to keep the MAF in play..
Heading to Barber MP this Saturday, when I left my house at 5AM it was around 45 degrees. The temperature change coupled with a drop in elevation (I live in GA, track is in AL) I saw up to 14% positive LTFT's on the way there (typically they are at 0 or -2 ~ -3).
Throughout the day the temps rose to almost 80 degrees.
The point is, there are very good reasons for running the stock MAF / SD hybrid configuration - a lot of "tooners" (stole that one from MD) will do MAF-only tunes because they are too lazy to do the real work to map the VVE tables. The sad part is 90% of the folks that have these tunes in their car have no clue it is setup that way.
#38
You data logged your entire trip? Dedication right there.
#39
Dan is correct. Very few if any people try multiple tuners or know what they are missing. They get the car tuned, it makes power on dyno, drives ok, and they praise how awesome their tuner is and how he/she is the best. I've seen local tunes that are complete crap yet the owners were happy because they don't know better.
#40
