C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] PCM/ECU questions.
Old 01-27-2018, 09:54 PM
  #61
EnginerdVT
EnginerdVT's Avatar
Originally Posted by Michael_D
PM me your email. I'll send you my file and you can use the HPT compare function to see all the different tables.
I did it so I could get more tables for tweaking the O2 sensors, but it does have other benefits as well. (you will need to download the beta HPT).
Pm sent.
Old 01-28-2018, 12:43 AM
  #62
0Chuck CoW
Former Vendor
Chuck CoW's Avatar
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default from what I can recall......
Originally Posted by EnginerdVT
This is the same discussion as before in trying to get the new ecm capability of larger injector tables and such for an older car (in my case an 08) to avoid scaling and loosing adjustability with larger injectors to run 1000+ whp with e85. I realize people have made it work with scaled tables but was trying to avoid that if possible and going aftermarket ecm is not worth it to me. I have heard that you can repin the harness to support a newer ecm.
from what I can recall...... The tach pulse or rpm reference pin has a different output state from one year to the next.
I have not made this swap yet here and I can only imagine that will will present other unexpected issues you might not expect.
In principal it should work, but different years broadcast different can messages so somewhere I would expect a problem to pop
up but I'd be very interested in knowing how this all unfolds it you decide to try.
Keep me posted.
Chuck CoW
Old 01-28-2018, 01:12 PM
  #63
Michael_D
Michael_D's Avatar
Pm sent.
Didn't get it.
Old 04-12-2024, 11:23 AM
  #64
NinjaKJ
8th Gear
NinjaKJ's Avatar
I know this is a VERY old thread, but I am potentially looking at a ECM replacement. What's the current path people take? I was going to talk to 0Chuck_CoW but he hasn't been online since 2020.
Old 04-12-2024, 01:31 PM
  #65
KENS80V
KENS80V's Avatar
You can buy a used ECM from eBay. They will reprogram it to the correct operating software once you give them your VIN. Once you install it a couple of factory relearns will need to be performed. A scan tool will be needed unfortunately. Hopefully you can find someone in your area to help with that.
Old 04-12-2024, 01:39 PM
  #66
NinjaKJ
8th Gear
NinjaKJ's Avatar
Scan tool? If it's just a code reader, lots of local auto parts stores do that. If it's more sophisticated than that, I'll have to look around. I'm in the Dallas/Ft Worth area, btw.
Are there any preferred vendors on Ebay? There's lots of junk I want to avoid.
Old 04-12-2024, 01:52 PM
  #67
KENS80V
KENS80V's Avatar
I have used and recommend SpareECM on EBay. A code reader will not work. It must be a more sophisticated Scan tool. Possibly someone reading this who lives in that area can assist you.
What year is the car?
Old 04-12-2024, 02:23 PM
  #68
NinjaKJ
8th Gear
NinjaKJ's Avatar
2006 z06
Old 04-12-2024, 02:25 PM
  #69
NinjaKJ
8th Gear
NinjaKJ's Avatar
I looked it up and yea, I know what a scan tool is. Why is a scan tool needed for an ECM swap?
Old 04-12-2024, 09:51 PM
  #70
KENS80V
KENS80V's Avatar
Your car came with a ECM #12597121. These were also used in many other GM vehicles around that time so should be fairly easy to find.
Scan tool is needed for a Crankshaft Relearn. If you are doing a crankshaft relearn with a scan tool then you might as well do the anti theft relearn too.
Old 04-12-2024, 09:58 PM
  #71
NinjaKJ
8th Gear
NinjaKJ's Avatar
anything else to know? I have no knowledge when it comes to these cars so explain it to me like I'm 5 lol. I spent a long time drag racing in the Ford world but walked away years ago
Old 04-12-2024, 10:00 PM
  #72
KENS80V
KENS80V's Avatar
Everything you need to know can be found on this forum. Learn to use the SEARCH feature.
Quick Reply: [Z06] PCM/ECU questions.
