[Z06] Lets see your stance...
#2723
Location: Retired early,everyday is Saturday...Hocking Hills Ohio
no, I don’t and I’m all the way down on stock bolts. just use common sense when approaching steep transitions/inclines and I avoid speed bumps altogether
#2724
Right now my measurement's are:
DF 25 7/8
PF 25 3/4
DR 26 5/8
PR 26 3/4
No issues on the front with stock tire size.
I just bought the car so I am not positive how low it is, but it looks LOW. I noticed the front pass bolt, the pad is disintegrated underneath it, but again this is the front. I don't have an issue with the front, it's the back on steep inclines going up at an angle it will rub/grind underneath.
Yes, speed bumps aren't an issue, just steep inclines at an angle when it shoves the tire all the way up in the wheel well.
DF 25 7/8
PF 25 3/4
DR 26 5/8
PR 26 3/4
#2726
That makes sense, my setup is stock size. I'm guessing I need to raise the rear a bit to eliminate the issue.
The following 3 users liked this post by Synister_z06:
#2729
#2731
tdf01cycling (11-20-2018)
tdf01cycling (07-13-2018)
#2737
Does this mean you left the girlfriend at home and took the car out?
#2739
The following 2 users liked this post by CabronZ06:
StancyPants (07-24-2018),
