C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Stoptech STR Trophy brakes, new in box
Old 07-13-2011, 04:03 PM
mshipes
mshipes's Avatar
Default Stoptech STR Trophy brakes, new in box
I have new in box Stoptech STR Trophy Brakes for C6 Corvette. 2005-2011 Base, Z51, Z06 and Grand Sport
ST60 Front calipers with slotted rotors, ST40 Rear Calipers with slotted rotors. Package retails at $7,300 plus shipping.
I would like to get $6,000 for the brakes plus shipping or if you are in southeast Michigan we can arrange either picking up or dropping off.
Any questions you can PM me here or email me at (m. shipes) (at) gmail (dot) com
What Stoptech says:
StopTech's latest racetrack and competition brake system comes with the new Trophy STR lightweight forged calipers in six-piston, four-piston and two-piston configurations. Based on the StopTech ST-60, ST-40, and ST-22 calipers, STR calipers feature the same metallurgy and design, but are engineered to provide a 20-percent reduction in weight without sacrificing stiffness or performance. STR calipers are also available in Sport Trophy kits designed for production street driven vehicles which utilize dust boots, anti-rattle rotor mounting hardware and include StopTech Street Performance brake pads. All existing StopTech kits can be ordered as Trophy or Sport Trophy kits.
STR60:
Fully forged aluminum construction with hard anodized finish
Patented, bolt-in bridge minimizes caliper compliance for a firmer pedal
Stiffest 6 Piston caliper currently on the market
Uses standard FMSI D1247 pad (VIEW PAD SHAPE)
Can be used on rotors with outer diameter of 328-380mm and thickness of 28-35mm
ALL finished parts are 100% leak down and pressure tested to 2500 PSI
Uses a popular pad shape readily available in over 15 street performance and race friction compounds
Over 19 different piston size combinations available to tune brake torque to the needs of each individual application
Differential piston sizes minimize pad taper for longer pad life and a firmer pedal
Dust boots are standard for reduced maintenance on Sport Trophy Kits
STR40:
ST-40 uses standard FMSI D372 pad (VIEW PAD SHAPE)
Any combination of 8 piston sizes available to match kit to vehicle application
Dust boots are standard on Sport Trophy kits
Same caliper used by top Speed® World Challenge and Grand-Am Cup Teams
Old 07-19-2011, 01:54 PM
mshipes
mshipes's Avatar
Correction, 14" rotors for the front.
Quick Reply: [Z06] Stoptech STR Trophy brakes, new in box
