[Z06] TRZ tubular k member
anyone running this set up? http://www.trzmotorsports.com/400.html
looks like this k member, a arms and rack could free up 70lbs!
dont see engine mounts... looks like would have to run a motor plate
hmmmmmmmmmmm
hmmmmmmmmmmm
It frees up 95 lbs......... for the serious drag racer, to go along with a manual steering rack that combined could potential save over 100 lbs over the nose of the car.
3200.00 , and probably the biggest weight savings in one upgrade other than the drag pack. I'm sure this is part of the weight loss program that allowed Sebast19X to get down to a claimed 2725 lbs dry weight.
It's VERY hard to get an already light C6 Z06 1LZ car under 2800 lbs........remember, even Jim Hall's feather light ULZ735 car with carbon wheels came in at a then unheard of 2785 lbs dry weight
that is insane!!!!
It is......but it does incredible things when you are 1/4 mile drag racing.
Even the carbon fiber deck lid/Lexan glass replacement from Katech doesn't get close to 100 lbs savings in one fell swoop.
The drag wheel setups from Weld and others, when paired with an appropriate tire, can shave 100 lbs off a car.
~STOLEN~ (10-30-2018)
Only thing that sucks, is having to switch to a dedicated drag brake. Which, I'm sure, is a majority of the weight loss. How do the strange brakes perform on a street/strip car? I'd venture to say they were designed to work along side a parachute and not the sole way of slowing down the vehicle.
Getting the car under 2850lbs is going to be tedious and expensive. My goal is to get the car to 3000lbs, with me in it. Luckily, I've put myself on a diet, so that might make it just a tad bit easier. I'm about 25lbs down from 256lbs. ::thumbs up::
so are you saying your car is no longer "fat guy friendly"......i was looking fwd to a ride when im down in tx next spring LOL
Cletus McFarland - Leroy
hmmmmmmmmmmm
hmmmmmmmmmmm
I’m buying Ti hardware at $125 a pop- lug nuts from ozmo engineering are awesome!
