[Z06] Mild to wild $89.95
Platinum Supporting Dealership
Mild to wild $89.95
DO YOU HAVE THE NPP OR Z06/ZR1 EXHAUST AND WISH YOU COULD CONTROL WHEN THE VALVES OPEN OR CLOSE?
WE HAVE THE SOLUTION THE MILD TO WILD SWITCH.
IT USES WIRELESS REMOTES TO GIVE YOU CONTROL OVER THE VALVES IN THE EXHAUST. INSTALL IN MINUTES. IF YOU CAN USE A SCREWDRIVER YOU CAN INSTALL THIS IN LESS THAN 20 MINUTES.
ALOS WORKS WITH THE B&B FUSION EXHAUST.
http://www.corvettesofhouston.com/pr...c573a28b5f5140
__________________
YOUR CORVETTE SUPERSTORE SINCE 1988
CORVETTE WORLD HOUSTON
281-821-1222
http://corvetteworldhouston.com/
281-821-1222
