[Z06] ls7 comp trunion upgrade
What were talking about is the re-installation of the rockers, and re-installing them with the valves open would cause tension/pressure resulting in an incorrect torque spec reading when tightening down the rocker mounting bolts
It requires less than 22 lbs to tighten the rocker bolt until the rocker seats against the head. In fact you can tighten the bolt and compress the spring using a stubby 3/8 ratchet. There's more than adequate thread engagement on the bolt and there's very little spring pressure when first starting to compress the spring while thread engagement is minimal. Since tightening the bolt requires less than the required torque spec there is no excessive wear on the aluminum threads. And finally, since the bolt doesn't get tightened until after the rocker is seated against the head, installation of the rocker while not on the base circle does not affect accuracy when tightening the bolt to spec.
Finished the Comp Trunion Upgrade / swap, and all I can say is WOW
Regardless of whether or not your C6 Z06 falls into the dreaded fail date of the bad batch of rocker bearings, EVERYONE should do this upgrade. Hopefully I got a video of what my Z sounded like before the upgrade, because the end results are amazing. The Comp trunion setup has less side-play or movement and has resulted in a FAR healthier sounding motor.
None of my factory rockers had failed or dropped any bearings and I'm indeed within the dreaded fail date range. But the factory side to side play between the rocker-arm and trunion was far too excessive (IMO). The end results with the Comp setup is AWESOME. This upgrade is more than worth it. Not only is it a more solid setup setup, but it provides peace of mind, and makes the motor sound 10-times better.
I'll be posting an extensive and detailed how to as soon as I get a few other things taken care of
The Comp trunion upgrade was one of the first mods I did when I got my car. Seems to be working great...last 5000mi. If found the Comp bolts to be way too long as well so I reused my stockers.
DH
Anyone have any feedback regarding using the trunion upgrade with high-lift cams or high-rpm applications?
Just currious how well they hold-up.
If they can handle high stress applications well, they would be the most economical rocker solution by a lot.
Ok thanks found them on summit
Also Would you guys suggest changing the Pushrods as well or Springs while doing the Trunion upgrade?
7.800 5/16 or would I want 3/8?
http://www.summitracing.com/parts/TFS-21407800/
If so, I would take your stock pushrods and roll them to check they are true and then leave them alone if they are.
It wouldn't be the end of the world if they got flipped around when removing and reinstalling, its just better to reinstall them as they came out. Valve lash......net build.......yada yada yada
#34
LS1 vs LS7
Take a look at page 9-1165 Engine Mechanical in the shop manual there is a detailed description of rotating the crankshaft to top dead center of number one cylinder tighten exhaust valve rocker arm bolts on 1,2,7 & 8 and intake rocker arm bolts on 1,3,4 & 5. Rotate the crankshaft 360 degrees and tighten exhaust rocker arms on 3,4,5 & 6 and intake rockers 2,6,7 & 8. Torque spec is 30 N-m (22 lb ft). The shop manual clearly states "DO NOT Tighten" the rocker arms without following the above procedure. Hope this helps.
#35
Supporting Vendor
Received 1,012 Likes
If in doubt or worried about the threads or incorrect torque readings then just make sure each rocker you are tightening is on base circle and your good to go. Although you can tighten them down even with the valves open, no harm done.
#36
I have been pondering this whole exhaust valve issue for quite some time, and am convinced, that a major contributor to the problem is with the rocker arms; while the stock rockers provide low mass, they allow a lot of friction and side load build up; this upgrade seems like a great compromise. Has anyone investigated whether or not installing this upgrade voids the factory power train warranty? My car has a lot of warranty left and I would not want to void the warranty.
#37
I have been pondering this whole exhaust valve issue for quite some time, and am convinced, that a major contributor to the problem is with the rocker arms; while the stock rockers provide low mass, they allow a lot of friction and side load build up; this upgrade seems like a great compromise. [...]
In fact, there is no evidence that the trunnion upgrade will do anything useful at all. Yes, I know the factory trunnions are often perceived as 'loose', but no one has ever reasonably explained or demonstrated how that is a 'problem'.
#38
And then only if you do the C.H.E. trunion upgrade, as the Comp upgrade still uses bearings.
#39
A trunnion upgrade will do nothing for "friction and side load". If you want to address those issues then you'll have to go to a roller tipped rocker, which then introduces all other kinds of issues.
#40
Should things happen to not be perfectly in alignment between pushrod, rocker arm pedestal, and valve stem tip then I'd think you'd want a little freedom of movement in the trunnion, wouldn't you?
Personally I suspect that may be why you see the occasional broken circlip on the CC upgrade... if the factory setup is not perfect in alignment, and when you constrain the rocker with a tight trunnion something has to give (the circlip).
If you loosen an old Gen I SBC rocker you can spin it 360 degrees on its stud. I'm not thinking lateral 'slop' is a big issue in the pushrod OHV design.
The side load that is of concern in that type of design is that imparted in line with the rocker arm, not perpendicular to it (assuming the lifter bores are machined in line with the valve guides, with the rocker pivot point in a mid-line location)... and that side load is simply the nature of the beast, regardless of trunnion or rocker tip. Wear pattern on the rocker pad and the valve stem tip will probably tell you if the rocker is having issues, in which case something more than a new rocker or new trunnion might be in order (something like a blueprint rebuild of the head or, in what should be an unusual case, the entire block).
