[ZR1] Anybody running nitrous on there ZR1?
Seems with the car having a forged motor stock, all the bolt on's and then some nitrous would be a Hot set-up.
Yeah I was wondering this as well. I was contemplating a twin turbo C6 or SC Z06 but then I thought why not do a bolt on ZR1 for 800hp and then a 150-200 shot. Seems like a good way to go.
We're running 150shot on our ZR1 shop project we're thinking about going 200shot very soon.
Kooks 1.7/8 headers / LPE 2.60 Pulley / LPE ported blower snout / LPE CAI / coollogic heat exchanger/ tune.
stock 530rwhp / mods above 625rwhp / 150shot 789rwhp after that we added a very mild cam made 649rwhp I believe if we dynoed it again with the nitrous it will be over 800+rwhp
Keep in mind the numbers were on 91octane 98F only 13psi and C16 Fuel with the nitrous.
With 16+psi and bigger cam 900rwhp shouldnt be a problem.
Video of the car before the nitrous
http://www.youtube.com/watch?v=6YMzn...g&feature=plcp
Check the other vid I can't post here 40-200+mph
I will post the new vids soon.
Are you still on the stock fuel system?
Did you mean "is there anyone running N0s on THEIR ZR1? Or are you asking where they are running the juice? There = location, their = possession, they're = what THEYare doing.
Former Vendor
The hill climb car is plumbed for it......
Plate kits do not work well with Positive displacement blower. like they do with NA and Turbo/Centrifugal blower.
Thanks I will do that
We're using NX nozzle system I'll see if I can get some vids or pics.
Completely stock fuel system only C16 fuel on the nitrous the stock fuel system is awesome.
So any update on your ZR1 ?? Congrats BTW
Yeah I read about that somewhere that's why we used nozzle system
Im going to make my long over do post this weekend. From day one that I got it I been doing something to it so I was holding off. I will post some nice pictures. I also just ordered some ADV.1 wheels so im pumped about that.
Im already to do a hp bump after the new year so let see what happens. Twin turbo or heads & cam. And maybe some nitrous if I can stay on the stock fuel system.
Just finished getting tuned on Friday. It has upper and lower pulleys, bigger cooler, CAI & headers on E85.
Keep us posted with the numbers and pics ADV.1 gonna look badass on black ZR1
IMO go with H/C and nitrous you'll be over 750rwhp with H/C on E85 maybe even more 14-16psi then add 150shot 900+rwhp but you'll need a bigger injectors with E85 for sure.
I remember IPS did twin turbo ZR1 everything was stock except the injectors made 910rwhp 15psi
It was a very very humid day
Thanks the car is amazing if I ever bought C6 ZO6 one of the 1st mods I'd is ZR1 5th/6th gear ratio
The Consigliere
Received 5,444 Likes
Did you go with larger injectors in order to move the greater fuel amounts required by E85, or can the stock injectors handle the greater volume?
I have a couple of questions in regards to the nitrous application. Do you install a wet or dry Nitrous system? It was a plate system or a fogger system? If it was a fogger system where the foggers were located, can you show a picture? Do you have stock injectors and stock fuel pump? I was under the impression that the car with already mods present was kind of short for the current fuel pump capacity.
