[Z06] Any regrets going to high compression & E85?
So far the injectors are holding up.
what if you pick a station that has the wrong blend. Winter blend/summer blend etc. Who wants the headache not me. Ask a few guys here on the forum with e85 cars that are and was on the for sale section. You can NOT SELL THEM WITHOUT SPENDING 4 GRAND TO PUT IT BACK STOCK.
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
A 93 octane pump gas max effort heads/cam set-up easily makes 600+ rwhp these days, and the compression ratio with the right quench can still be run at real close to 12:1 to CR, so just not worth it in my opinion for a small performance gain, when just about the same can be achieved on pump gas (without the hassle and need for multiple tunes, etc.).
Just my two cents and that's all it's worth!
Here in Michigan we have a ton of e85 stations. However, I decided against going e85 since 93 octane is the standard premium in this state. Sunoco also sells 94 octane. Wasn't worth the pros vs cons on my end.
With all the people running E85 why do you think others have not reported this?
Yikes! I have not heard of that issue, that could be dangerous to develop a leak in that area. Your saying that the first set of O-rings were damaged by the E85 and then he replaced them and the second were gone in a month?
3rd set was back to GM's O-Rings and no problem since.
Fuel was not pouring out of the fuel cell.. just upon inspection of stuff I could see where it was damp and slowly running running down the frame rail. But yes a potential serious problem.
As far as the E85 Disscussion its mostly already been said.
Pros:
Smooth Power!
Lower Cylinder temps
Cheaper than 104 octane
Smells like popcorn!
Cons
Fuel Consumption
Avalibility
Fuel supply upgrade
Any one try a meth injection system instead? Same results as e-85 that is only being used when needed.
I have been running e85 in my evo for years and i love the stuff. The only thing that is stopping me from running it in my Z is that I daily drive my Z from march/april til snow fall and at the moment just has bolt ons. The main reason i would even consider it is due to the cooling effects that it provides(cant beat having december like air all the time). I know first hand how bad the MPG's get with using E85.
Premium Supporting Vendor
I've been running E85 for 17 months and I don't have this problem.
As far as the mileage, exactly 30% drop as expected.
#34
The first set was damaged during removal of the cross over tube. (lesson learned) The second set was not GM O-Rings.. They were O-rings that we use on our construction equipment. Right size, but not the right material for E85/Gas usage.
Thank you for chiming in and clarifying that.
#37
If you want to get some major bang for your buck with E85 stick it in your CTS-V, you can run 10 degrees more timing and end up with upwards of 150 extra hp
Cheers, Paul.
#39
#40
