[Z06] New Lower Price! 6000k Low Beam Upgrade **$69.99**
Former Vendor
St. Jude Donor '12-'13
We have had countless requests by forum members to source a reasonably priced low beam replacement bulb to update the OEM HID bulbs in their C6's. As many of you notice, the 4300k HID's that are stock in C6's are not far from the yellow tinted appearance of a halogen bulb. It even becomes more evident when you see them side by side:
Before:
After:
Corvette Mods solution? 100% plug and play replacement bulbs that work off your stock wiring! No modifications whatsoever required.
These replacements are rated at 6000k, which is more of a clean white color over the stock 4300k yellow tinted lows.
You don't need any special skills to perform the swap either!
NEW LOW PRICE $69.99
Click here to order:
http://www.corvettemods.com/Corvette...de_p_5597.html
Pair these up with our switchback DRL LED's and HID Fog Light conversion kits for a perfect lighting upgrade
Click this link to go to our Fog HID conversion sale thread!
http://forums.corvetteforum.com/c6-p...77-99-a-3.html
[/SIZE][/B]
Before:
After:
Great upgrade over stock! Quick and painless install, and it's much easier if you remove the front wheels to get better access to the headlight assembly. I'm very pleased with my low beam/fog combo!
Received 1,497 Likes
No-IL Events Coordinator
C6 of Year Winner (appearance mods) 2019
2018 C6 of Year Finalist
St. Jude Donor '12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Is this primarily for color, not higher output (power)???
Thank You!
Thank You!
