[Z06] Conversion of Early Dry Sump (8qt) to the Late model (10½qt)
Has anyone had any experience with converting their 8qt dry sump to the newer 10½ qt dry sump? I am considering the change because at greater than 1.3 g's the bearings can become oil starved. And since I track the car using Hoosiers, I was advised that sooner is better than later.
I notice that the GM 10½ qt dry sump appears to have a different oil cooler compared the earlier Z's.
Was wondering if the older oil cooler must be swapped out in favor of the newer one when the oil tank reservoir is changed to the larger capacity reservoir?
Any comments would be helpful.
GM added an extra tank to the side of the main reservoir to increase the volume. All the Z06's use the same oil cooler except for the 2011 & 2012 which use the ZR1 oil cooler that is mounted to the side of the oil pan, and uses the radiator's coolant to heat/cool the oil. If you just want to increase the capacity, get a later(2009+) reservoir or a LPE modified reservoir(11 qt capacity system vs 10.5 with the GM reservoir).
Conversion
I did the conversion it takes about 2 hours. I did the LPE one and I have a 2006.
Does the LPE conversion come with directions? If you completed the conversion in about 2 hours, I take it that fender removal was not necessary as it would be with swapping the older 8 qt GM reservoir for the newer larger GM product?
Hopefully the oil comes up to temp faster, cause the '06 I have takes a long time to get past 150 degrees....
I might need to add that I have 3 small children, and only limited periods of time alone with my baby...so wasting it waiting for the oil to come up to temps sucks!
The oil pan on the ZR1 and later model Z06's have a couple of tapped bosses on the side of the pan(that the earlier cars don't have) in which to mount the heat exchanger. If you wanted to go with the later style oil cooler you would have to get the newer style oil pan or make some special mounting brackets.
I beleive that is what Edelbrock did(special brackets) to be able to use the newer style cooler so they could get rid of the heat exchanger in front of the condenser so they could mount the supercharger's heat exchanger in that location.
I don't worry about it, as I very seldom drive the car when the ambient temps are below 50 degrees.
Premium Supporting Vendor
The tank has nothing to do with the new oil cooler.
Since I did the conversion I switched over to an ARE Stage 3 system, so I have my old 10.5qt tank for sale.
http://forums.corvetteforum.com/c6-p...-complete.html
The cooler and tank are in different areas of the oil circuit. You can do one without doing the other. Of the top of my head you will need the cooler, oil lines, the different surge tank hose, and the fitting for the block.
http://forums.corvetteforum.com/c6-z...tallation.html
In the process of installing the OEM '09 tank into my '07 Z and have discovered a problem. The '09 plumbing harness fittings that attach to the rocker arm covers are different. I purchased the '09 plumbing harness to make the install easy but it has become anything but. Any suggestions would be much appreciated.
