[Z06] Street Attack LS7 fresh off the dyno 620hp/580ft-lbs
Premium Supporting Vendor
LS7 crank
LS7 rods - rebushed
Katech rod bolts
Forged 2618 pistons
Katech Torquer LS7 cam
High speed lifters
WCCH heads
Bronze valve guides
Katech Ti/mo intake valves
LS7 exhaust valves
C5-R timing chain
ATI damper
Katech blue oil pump
FAST intake
620hp, 580 ft-lbs
Ready for install into the car next week
Stock compression ?
Think he meant 575rwhp on a Dynojet, per your previous posting. Motors always make make more power when the headers are pointing forward
Seriously though, nice numbers Jason!
If so it's possible on the right dyno. I made 560rwhp (Mustang dyno) with my car that has a Torquer cam, FAST manifold, ported heads, 12:1CR and E85. On a more generous dyno it could probably push close to 600.
How much HP over factory
Is factory motor on your dyno 525 nad like 490 due to stp factor? So basically picking up about 100 hp and 90 ft pounds of torque?
OE injectors?
Don't suppose you have a graph with the pull starting at 2000 do you?
Is this the 110 or 116 lsa torquer?
Can you clarify "high speed lifters"? I'm assuming they are short travel, light weight aftermarket?
thanks
thanks
110LSA
GMPP Cadillac Racing lifters - lightweight.
videoThis is the car with the motor in it at VIR using 4th gear only all the way around the track no shifting.
Coming out of the oak tree your at about 2000 rpm and 43 mph at the end of the straight its 163 mph so the torque and power start low in the RPM. If video doesn't work go to ED7577 at youtube
Supporting Vendor
St. Jude Donor '09
Jason forgot to mention that the dyno they use has the Super Bee MF103 on upside down as their default intake for all dyno pulls.
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
www.halltechsystems.com
262-510-7600
For service email:
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Great combo.... Damn I want to do this to my z06..., but with 2 years left on GMPP I hate to break modify it!
