[Z06] Blown Engine
#41
could be more common than you think, on track doing a buck 20 in third corner coming, traffic, mind gets side tracked and you need second gear and you shift only to find out your still at 103mph, wa la over rev. A couple weeks later you drop a valve on way to the store.
#42
Have you ever examined a blown LS7 with a dropped valve (over reved or not)? Have you ever examined ANY blown engine with a dropped valve? No, I didn't think so. Enough said.
#43
We try to prevent the problem before it happens. Whenever i sell a cam package to someone i always STRONGLY recommend them getting the exh valves replaces. I would say i have seen it happen to 10-15 personally and NUMEROUS others on the forum.
I couldnt even begin to estimate how many LS7's ive worked on. 100's
#44
There are so many C6 Z06s with 40, 50 even 75k on them that are bone stock or close to it This subject has 98% to due with the person in the drivers seat not the LS7 but the talk scares so many people from this awesome car.
The grand sport is a funny thing just enough added horse power to move those massive Z06 size wheels and tires to basically the same performance numbers as a C6 coupe and all just to look like the awesome Z06.
I would love to take all detractors for a ride in my red 570hp Z06 I paid 45k cash for. It came with 4024 miles lowered on springs with black spiders and I did the carbon fiber side skirts and front splitter, full Akrapovic with headers, cold air intake and tune. It looks awesome and runs like the beast it is, there's nothing like firing up those 427 cubic inches
I'd love to have a Zr1s they are the real deal but Im not dropping that much cash at this time
I know how to drive, keep the oil fresh and full and always let her warm up first...But if the need for an 650hp LSX or Katek ever presents its self then...life will get even better. Maybe I'll do it @ 50k mile and sell my LS7 to someone who fires theirs up and raps it out in the drive way to impress the neighbors
BTW anyone who wonders if you can blow up a 505hp 427ci aluminum small block must have not have been raised in a racing culture, please!! there are teenagers at your local drag strip smarter than that. the amazing part is not that you can blow it up but that GM made a actual race car that can go 75k mile without having to rebuild it every two years.
#45
A friend in high school blew up his aunts 1971 type 3 VW fastback sedan power shifting from 3 to 2 when he meant to go to 4th.
I bet most of these LS7's that blew up had some sort of user error - either inadequately filled with oil and doing heavy track time, or constant bouncing off the rev limiter or power downshifts.
Those that blew up as their owners reported while nonchalantly idling or driving down the road at 50 mph under 2000 rpm, probably had experienced significant abuse, or improper oil levels or driver error sometime prior to letting loose while humbly cruising down the road.
that being said - I went ahead and sprang 1500 bucks for a GMPP just in case mine blows while gentley cruising down the road
#46
Unfortunately GM didn't outline a PM program for cars that are tracked every weekend. It's more than just changing oil but I believe they assumed there was an abundance of common sense.
#47
Do a search on the forum. If you think that over spinning on a premature down shift, floating a stainless valve making contact with piston won’t bend or break it, your either smoking something or out to make a buck. Also as valve springs fatigue with time and use they resonate or float at lower and lower rpms even below the protective rev limiter.
