[ZR1] Horsepower of LS9 without supercharger?
Former Vendor
Small, unknown fact, the PCM will open that bypass when IAT2 gets above ~250*F I believe.
On the cars that have the wick turned up, this table can be very apparent if the car has been beat on for long period of time or the coolant for the blower wasnt properly filled/purged/burped.
Louis
Louis
Holy cow vendors. Can we say:
VALET SWITCH??!?!?!
How about someone put together a nice reasonably priced plug and play circuit that is controlled by a cheapie remote (just like the mild to wild switch) and activates the bypass when you have to valet the car or take it in for warranty/service to the dealership?
I can't believe GM didn't do this from the factory like they offered for the C4 ZR-1 with the valet key.
VALET SWITCH??!?!?!
VALET SWITCH??!?!?!
VALET SWITCH??!?!?!
I was thinking the same thing about the valet switch. I was suprised at the 420rwhp number because it felt like a real dog when I was driving it that way. I guess you just get use to it feeling one way. Pull it and see what I mean.
Former Vendor
I was testing boost solenoid duty cycle results and effects 3 years ago and that bypass valves job in the whole realm of the system, which is how I came across it. I might be able to dig up the graph.
Hey Louis did you do any testing where you kept the valve closed in the high boost condition to see what if any extra boost could be had. I doubt it would be much, maybe and extra lb in good air.
By the way I still have that picture of you and Lou under my Camaro trying to install a torque arm at the F-body event in Memphis many years ago.
