[Z06] C6zo6 tips the scale @ 2980lbs!!!!
Awesome. I think my favorite thing about these cars are the weight.
I was reading about the new Focus ST coming out, little "tuner" car or whatever, focus with a ecoboost 250hp, good brakes and suspension, a little hatch like a SVT focus version basically
Damn thing weighs almost 3300 lbs
Truck stop scales are VERY accurate.They have people come out and test and adjust them monthly.Most truck stop scales are CAT scales and they are guaranteed accurate.
Everything I JUST did and plan on maybe doing are reversible and could be put back to stock in 1 afternoon. FYI, this is not my daily driver-more of a weekend warrior. I don't road race and want this thing nasty fast in a straight line. I realize their is a "weight reduction" thread, but it has not been updated in over a year. Would like to know the weight savings from Borla stingers---> straight pipes(10lbs?) if their is lighter(18") rear drag pair than my 49lb setup? I'm sure the 275/17" c5 setup, but imo would look silly cruising the streets. If I did not get the acp wc hood used, I would have never bought, as was disappointed with only -5lbs, but it looks cool and I'll run coolER. Front afx rotors are an option as I may need in the future-no rear rotors needed. I would love to get the hre comp 21's, but $5k for 5lbs is quite pricey. New hood, halo/roof,phadt cf driveshaft, and deck lid are for the rich. I see the new coilovers from LG are light, but I would not maximize their use on the street. My invos still have a good amount of tread on them, but I see their are lighter options-will go that route when needed.
I don't drive this car in the summer months or in the rain, so removing the a/c, wipers and washer tank is an option, but sounds like to much of a hassle- I wil atleast drain washer tank. If I can find a used race seat I may purchase. I like the Caravaggio seat that Jim and Jason are using, but not at $2k a pop. I'm pretty much tapped out on power except for nw tb and porting my fast. I thought about swapping my lethal cam for a striker, but was told it will drive like ****-but this is my race car and 20rwhp up top sounds nice. again I will not cruise around the streets/highway with skinnies. Pictures of the car are unimpressive right now as the hood is on for a test fit and was bought used(blk/yellow) on an all black car. The rear wheels are also the stock c5z gray as the fronts are black.
Thanks for the help
Thanks for the help
I believe this one is, as I weighed every piece that came off
2795lbs????
Food for thought- (starting at 2980lbs) these are good estimates. Some more, some less. Please correct me if I'm waay off here
-35bs pass seat delete
-5lbs lighter Michelin front tires
-5lbs hre comp 21's/Forgeline ga1r
-5lbs straight pipes
-30lbs rotors
-5lbs phadt cf driveshaft
-15lbs LG g2 coilovers
-10lbs cf drivers race seat
-10lbs Halltech cf hood
-15lbs cf halo/roof
-30lbs Katech deck lid/lexan
-10lbs phadt sway bars
-10lbs Hoosier drag radials
Prob about $25k here in parts/labor for 185lbs
2795lbs!!!
I'm goin for it
...........when I hit the lottery
-30lbs rotors
-15lbs cf halo/roof
2795lbs!!!
I'm goin for it
-35lbs pass seat delete
-5lbs hre comp 21's
-30lbs rotors
-15lbs cf halo/roof
-10lbs a/c,wipers,washer tank
2795lbs!!!I'm goin for it...........when I hit the lottery
-5lbs hre comp 21's
-30lbs rotors
-15lbs cf halo/roof
PS I don't know if you actually save that much weight with a racing seat now that I think about it b/c you need to add a harness bar (or cage) and an extra set of belts.
If you don't install it yourself (or even if you do) you're looking at way north of $25k! But yeah, go for it man, that would be the sweetest ride on the planet. Also, for a cheap solution, delete the A/C system altogether will save more than 10 lbs. Straight pipes save WAY more than 5 lbs. Also look into lighter weight batteries. The real trick is to get the car under 3000 lbs with you in it, and get over 600 RWHP at the same time. <5 lbs/HP is where it is (stock Z06 is over 7 lbs/HP).
I was thinking 575-600rwhp. I'm at 565 now. The deka battery is 18lbs, but I could go lighter and also a lighter clutch. I would delete the a/c system as I don't drive in the summer. Car is 3160 with me and 1/8 tank of fuel. How much are you thinking parts/labor for that list? I'm sure their is a few other things I forgot. I could always add an extra 25lbs back in and squeeze a 100-200 shot on my built shortblock, but I'm done with nitrous. Hmmmmm 800rwhp@2795lbs.......
If you place your car with the wheels between two of the scales, you can see how much weight is on the front and rear wheels.
The scales have 3 scales to weigh 3 sets of axles, place the front wheels on one scale and the rears on the next scale and there you have it.
#33
-bummer!
#34
#35
The NRG fiberglass seats are 12lbs (Seat only no bracket) and only $200 from Assaultech. I'm planning on picking a pair up soon. Here is a link to the seat specs.
http://new.getnrg.com/products/inter...seat-spec-list
Assaultech link
http://assaultech.com/nrg_innovation.../i-287094.aspx
Assaultech link
#36
Assaultech link
Assaultech link
#37
Assaultech link
Assaultech link
#39
They are actually 25lbs for the fiber glass ones that cost $200. The carbon fiber ones that weigh 12lbs are $700.
#40
