C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] Hello belt slip
Old 05-06-2012, 10:39 PM
whatcop?
whatcop?'s Avatar
Location: Daytona Beach/ Atlanta---- Good Ol' Florida Boy/ Georgia
Default Hello belt slip
I am having some nasty belt slip and so is narush. Figured I would make a separate thread so this doesn't get lost in his thread if someone is searching in the future.
Going to call around tomorrow and see who will make me a pulley in the same size that will prevent slip.
Old 05-06-2012, 10:47 PM
Quiky One
Quiky One's Avatar
I don't think an OD lower pulley will overspin the powersteering pump if that is your main concern...do the ZR1's not run a dedicated 12 rib belt to the supercharger? The smaller 4 rib pulley stays stock size, FYI.
Old 05-06-2012, 11:19 PM
whatcop?
whatcop?'s Avatar
Its 11 rib
From LPE's site:
This balancer upgrade overdrives the speed of the power steering pump and the water pump on the LS9 engine because they are all driven from the same pulley and is not recommended for road racing or sustained high rpm applications.
Old 05-06-2012, 11:33 PM
911/Q45
Support Corvetteforum!
911/Q45's Avatar
So this means you can have the power, but you can't use it?
Old 05-06-2012, 11:38 PM
Sherminator
Sherminator's Avatar
Start with sandblasting the pulley and running the absolute tightest belt you can run which will require adjusting the drivers side idler diameter to accept the few belts lengths available.
Old 05-06-2012, 11:41 PM
whatcop?
whatcop?'s Avatar
For drag racing or on the street it would be fine.
I would do this but the belts run for about $100 plus the price of sand blasting. Pulleys run for about $100. So I may as well go directly to what will fix the problem instead of hoping the sandblasting and tighter belt will solve the problem.
Old 05-06-2012, 11:45 PM
whatcop?
whatcop?'s Avatar
This might be an option also if it can provide more tension than stock.
http://www.compperformancegroupstore...BeltTensioners
GIO-305
GIO-305's Avatar
Look into the green belts that the blower guys use. I been told that they don't slip
Old 05-07-2012, 12:07 AM
whatcop?
whatcop?'s Avatar
It doesn't look like they carry an 11 rib. I'll call them tomorrow and make sure.
Old 05-07-2012, 04:53 AM
4MuscleMachines
4MuscleMachines's Avatar
That's what I had to use on the engine in my avatar and it did make a good difference (but not eliminate it). Also make sure no chewing of the belts is happening on the inner and outer edges.
Old 05-07-2012, 09:48 AM
LEAVINU
LEAVINU's Avatar
You sure do have a lot of issues with your car there Peter.
Old 05-07-2012, 12:19 PM
whatcop?
whatcop?'s Avatar
I am at the extreme end of testing the capabilities of a product lol. If someone wants to know if their product will survived 99.99999% of their customer base they can just send it to me and if I don't break it then you know its good to go.
Old 05-07-2012, 12:25 PM
venomws7
venomws7's Avatar
What size pulley? how much boost?
Good luck man.
Old 05-07-2012, 01:23 PM
whatcop?
whatcop?'s Avatar
Good luck man.
I have the 2.35 pulley with the 76mm idler. If I am correct I am only seeing 15lbs of boost whereas narush was seeing 17lbs.
Old 05-07-2012, 01:30 PM
narush
narush's Avatar
I have a similar setup BUT have the 2.35 pulley a 100mm idler and yes indeed seeing 17lbs
Old 05-07-2012, 01:53 PM
whatcop?
whatcop?'s Avatar
Wait you sure you have the 100mm idler on there? It calls for the 76mm with our setups.
Old 05-07-2012, 02:17 PM
whatcop?
whatcop?'s Avatar
Just measured mine and it looks like my idler is 100mm
Edit I remeasured and it is the 76mm
To Hello belt slip
Old 05-07-2012, 04:36 PM
gonabite
gonabite's Avatar
Narush is using the 100 mm idler because he is also using the OD crank pulley according to his post.
Whatcop, the belt that lingenfelter sent with your 2.35 pulley and 76 mm idler fit with no problem? I could not get that belt on to save my life, I stretched it so much trying to put it on that it ripped. Ended up using the stock 90mm idler and stock belt. I will be having the car tuned tomorrow by East Coast Supercharging.
Old 05-07-2012, 05:40 PM
whatcop?
whatcop?'s Avatar
Spoke with Narush today and he confirmed his is the 76mm and he does not have the OD pulley just the 2.35 pulley like me. Did you release the tensioner when you were putting the belt on? You have the correct 82.5 belt from lingenfelter. The stock 90mm idler would be bigger than the 76mm idler so it makes no sense how that would be easier to slip the belt on.
Old 05-07-2012, 05:49 PM
narush
narush's Avatar
To install it is best to put idler on last after belt is wraped properly that was the only way mine went on. But I bout the same setup as you. Please post your numbers and dyno.sheet so we can compare.
Quick Reply: [ZR1] Hello belt slip
