[ZR1] Boost Mapping our supercharger
Had a buddy take the map I found posted by Katech and work out all the numbers on it.
Check the CFM flow on these throttle bodies that are machined and polished so I would assume their 90mm flows better than ours. Their 90mm taps out efficiency at 1170cfm which means if we go by that scaling we start choking the blower at 11.5lbs of boost at the 6500rpm mark.
http://www.wilsonmanifolds.com/produ...le-bodies.html
