C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] any 3.90 or 4.10 gears coming soon for c6z diff
Old 05-18-2018, 04:43 PM
  #381
Dan_the_C5_Man
Dan_the_C5_Man's Avatar
Well, it's good you caught it before a chunk jammed and took out the case.
Old 05-18-2018, 05:10 PM
  #382
FNBADAZ06
FNBADAZ06's Avatar
Very true.
I had a spare low mileage C6 Z06 diff in reserve if this one was damaged.
The case itself was inspected and checked, as well as the carrier (diff) before it was decided to go ahead and put the gears in my original diff (90K miles on it). I had always planned on putting new updated carbon clutch packs in, and it was during that process that the broken spider gears and cross pin were discovered.
Old 09-25-2018, 12:10 AM
  #383
franko9217
franko9217's Avatar
Ttt
Old 09-25-2018, 08:07 AM
  #384
0Jeremy@RPMTransmissions
Former Vendor
Jeremy@RPMTransmissions's Avatar
We have these gears in stock and ready to build differentials or ship to your builder of choice.
Old 09-25-2018, 06:09 PM
  #385
mayracn
mayracn's Avatar
Typical cost for gears in Z06? With you work installing them in diff.
Old 09-25-2018, 06:13 PM
  #386
RobGOV-DCZ
RobGOV-DCZ's Avatar
have you heard about Motive or anyone else possibly building 3.73 for the Z06 diff in the future?
Old 09-26-2018, 08:03 AM
  #387
Former Vendor
Gear, labor and seals is $1,400.00 if you ship us your differential.
I don't believe they are going to be making a Z06 3.73 unfortunately.
Old 01-19-2019, 10:13 PM
  #388
jimbob8915
jimbob8915's Avatar
So what parts are necessary to change out other than the gear set? Where is a good source for a Z06 seal, bearings, an shim kit? Is a Z06 kit the same as a base?
Old 01-20-2019, 12:11 AM
  #389
Mike44665
Support Corvetteforum!
Mike44665's Avatar
Way too many special tools, Z06 and base diffs are NOT the same. The spline count on the transmission output shafts are not the same. I pulled my diff and took it to RTK in Fredrick MD. I don't know where you are at so shipping may play into it. I'm very happy with mine, car says high 23 low 24 mpg on the highway, running through the gears is a blast. If I ever get nailed for speeding it will be because of third gear, THE passing gear.
FYI
This is how the ring & pinion are in our cars. The front of the car is to the left. The long output shaft goes over the differential then engages the pinion gear. With the pinion above the centerline of the differential it makes for a rather odd pinion, since it is not on the centerline like you may have see in a regular rear end. In addition the ring gear count stays the same (3.42, 4.10), so the entire tooth form must change to match the number of teeth on the pinion. The speed pickup is reading the number of teeth on the ring gear so nothing changes here.
I just set it up for a picture, the pinion may be in the wrong location.
Old 01-20-2019, 07:59 AM
  #390
double06
double06's Avatar
Mike 44665 - did you notice a big change in acceleration when you went to 3.90s and is there any gear noise?
Old 01-20-2019, 08:34 AM
  #391
Mike44665
Mike44665's Avatar
I went to 4.10's.
Yes a big change, first gear is red lined very quickly.
They are quiet, RKT does good work.
I changed diff lube at 500 miles, ran 1,000 and changed it again. A little darker than normal first time, just fine the second time. Really never pushed it hard till after 1,500 miles. You can now use sixth gear, not so many 6 to 5 shifts cruising the back roads now.
Very happy.
Old 01-20-2019, 10:26 AM
  #392
jimbob8915
jimbob8915's Avatar
I am in California. Who would be a good choice to have my factory rear re-geared? I see RPM can do it to the tune of $3500 BUT they are installing a lot of other high dollar stuff. I want just a simple gear, seal, shim swap.
Old 01-20-2019, 12:49 PM
  #393
jimbob8915
jimbob8915's Avatar
Just got a quote fro Rick at RKT for $2000. Disassemble/inspect/clean/have micro polished 3.90's installed, new seals, an return shipping. I am gonna do this mid to late February.
Old 06-14-2020, 05:08 PM
  #394
slarsen47
Cruising
slarsen47's Avatar
Originally Posted by TJ@RPMtransmissions
400-450 rwhp cars are known as drivetrain breakers.... People drive them too hard trying to make them fast.
500+ rwhp cars rarely break becuase you have to finess the car to make it work.
This has come from years of working with C5/C6 drivetrain.
We have over a hundred of C6 diffs in C6 Z06 cars. I personally have a 3.90 in my Z. We have a very low number of them come back broken, and those that do know they were abusing the differential.
I am aware of the one year only 2005 diff issues.
Is the C6 diff stronger than the C5 diff?
And how do C5/C6 diffs compare in strength with the C4 D44?
Quick Reply: [Z06] any 3.90 or 4.10 gears coming soon for c6z diff
