[Z06] Best way to fix engine block surface? Coolant leaking on new engine.
I received my new engine block with some scratches and an indentation on some of the mating surfaces. I lightly cleaned everything up with a fine file and 1500 grit. However, after starting up my new engine I have found that an indentation hear the #8 cylinder water jacket hole is allowing coolant to leak out from the rear of the head and also into the #8 cylinder. Very upset and frustrated. I drained the oil, and coolant came out first. Not alot but some. Then I drained the coolant too. Also, drained my catch can because it had oil in it too. Long story short, I pulled the head and checked out the gasket, everthing was torqued properly, using all new parts to include ARP head studs. So now I am faced with trying to repair the "dented" part of the block surface to stop it from leaking when I replace the head gasket, put it all back together and hope it doesnt ever leak again. So, what miracle epoxy should I use to fill this void? I don't think JB Weld is going to cut it, and have been looking at other, higher temp, permanent epoxies for use. Anyone with experience with this, PLEASE advise. I really dont care to yank the shortblock and do it all over again. (obviously decking the block or replacing the shortblock would fix this)
Do you have a picture of the "dent". Is it on the edge or near the waterjacket?
I'm going to do what is normal for me and ask the dumb question:
Why didn't you take the engine block back and get one that wasn't dented ? Whoever supplied you with a messed up block should be trying to fix the problem.
On the other hand, your working on it with sandpaper and a file will get them to claim you caused this problem.
Just my 2 cents.
Just my 2 cents.
Just my 2 cents.
Just my 2 cents.
Landru (03-14-2017)
Forget about "1/16 inch." No gasket is going to seal that. In fact, to do it right, you'll need to build up the area and then fly cut it flat. Welding is ok, but it may warp the block from heat. You can heat the whole block and fly cut the whole block, but that's still a risk.
If it really a sixteen of an inch, that's .0625.
You need to get it down to .003in to .004in max.
If all else fails, they make a good table base...
I hate to say it but I think the dreaded fill with "Jb weld is the answer!"
damm that sucks, i think it's too critical of an area that cant be done without actual machine work, if it was where the oil pan meets the block, or the front cover then a JB weld would be ok but not on the cyl head to block surface.
Was the liner damaged? I would not think the coolant could get past the steel liner. What does the piston look like? Is coolant actually entering the cyliner, Or is there some other issues? Just not sure that is the actual issue.
Very High Tempature Permatex
The copper stuff. Though if the whole is 1/16 of an inch deep that is a lot. Maybe if it were 1/32.
If this doesnt work, then I guess I will have to pull the motor and have it repaired somewhere professionally.
This shortblock has never left the garage (zero miles) and has ran no more than a total of 30 minutes.
