C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Coolant Temperature Guage Error
Old 07-11-2012, 11:59 PM
SmokeyD
SmokeyD's Avatar
Default Coolant Temperature Guage Error
Have an message on dic to turn off ac engine running hot. Temperature guage at 0. Also got a message to add coolant, coolant level is about an inch below expansion tank. Infared pyrometer on coolant hoses 195 degrees. Turn car off and let set for an hour re fired car coolant guage works temp 195. Take the car for a spin and hammer it thru 3rd gear coolant guage stops working and get the same messages. Im thinking a coolant sensor?
Old 07-12-2012, 08:31 AM
tim414
tim414's Avatar
St. Jude Donor '12
Have you done any work or added mods...? What year?
Old 07-12-2012, 11:03 AM
VetteVinnie
Support Corvetteforum!
VetteVinnie's Avatar
Received 1,642 Likes on 1,050 Posts
I had that problem. It's tuning related if you have a 160 degree thermostat. Coolant temp doesn't get up to operating temperature quick enough, and you need to compensate in the tune so it doesn't trigger this.
Old 07-13-2012, 12:44 AM
SmokeyD
SmokeyD's Avatar
2006 kateck cam kooks headers kn cai.
Car has been running good except a little cam surge.
I had just changed out oem plugs for ngk tr6.
Could it be the colder plug?
Old 07-13-2012, 01:00 AM
jedblanks
jedblanks's Avatar
Not likely your problem, but keep in mind that the coolant sensor only senses water temp, so if you have air in the system or or some other reason the coolant sensor isn't touching the water, it will read zero. Usually only happens if you are completely out of coolant.
Sounds like your problem is in the tune.
Old 11-23-2015, 06:20 PM
Z.06
Z.06's Avatar
Default Not a Coolant Temperature Gauge Error
Mine was working fine yesterday and started out OK today, but 4 or 5 miles from home I got the coolant temperature XXX message on the DIC and the gauge went to the bottom peg. Then I got the massage not to operate the AC due to excessive coolant temperature. Originally I though the radiator fan plug had melted, a know failure mode, the checking showed that the fan was still operating and the radiator did not seem overly hot.
I tried jiggling the coolant temperature sender wiring but this did not have any result. I think it is the coolant temperature sender itself. The male wiring plug does not want to disconnect. I will try it again tonight.
I think my cheap-o Chinese made Sears VOM is on the fritz, and I will have to buy another tomorrow.
How do I burp the air out of the head after I replace the temperature sender?
Old 11-23-2015, 06:28 PM
v8sten
v8sten's Avatar
EViL427 nailed it right on the head, your car should be throwing a DTC. On your DIC go to the Water Temp and it should read "XXX". for now go to any autopart store and clear the code and it will work fine. take it to your tuner and he should be able to see it in the DTC History and desensitize it so it wont come back on.
Old 11-23-2015, 09:56 PM
Z.06
Z.06's Avatar
Default Coolant Temperature Gauge
v8sten,
I know EViL427 and Jedblanks both. While my impression is that I am seeing an ECT failure or a transmitter wiring conductivity issue, I am more than happy to accept their suggestion to check for codes and erase codes first in hopes the problem will be fixed by ECM reprogramming. As a matter of fact, this hope was the reason I put my issue out there.
So this is my next course of action. Of potential interest for the CF participants, the 160 degree tstat was installed 2.5 years ago at the same time as my cam and initial tune (by Lethal LLC in Lafayette). My ECM is currently on its third aftermarket tune, which was performed by 510 Racing in Tomball. My initial impression was that the 510 Racing tune was perfect. Since that tune, I have seen very few rough edges that could be improved by tuning. I have also been through 2 winters, which I would have expected to expose the type of problem that I am having now. Let's see where this goes.
Old 11-24-2015, 01:57 PM
Z.06
Z.06's Avatar
Default Coolant Temperature Gague
This is confirmed as a tuning issue. When I started the car this morning, the Engine Coolant Temperature is "XXX" was still there. Since I knew the engine was not hot, I drove it a short way. The first temperature I remember seeing was 165 degF. I still took it to an autoparts store and a code had been lodged. So it looks like my tune needs a minor modification.
I am still surprised to have only seen this message once in the two years since the 160 deg thermostat and tune was installed. Just glad to understand the issue.
Old 11-28-2015, 01:08 PM
VetteVinnie
You're seeing it now because it's cold outside.
Old 11-28-2015, 06:38 PM
blkbrd69
blkbrd69's Avatar
True;
The car looks for a coolant warm up rate. A 165 thermostat and no tune have thrown this with 3 cars before I tuned them.
Can be cleared by disconnecting battery but will just keep coming back till changed in tune.
Old 12-17-2016, 04:54 PM
redrocketship
redrocketship's Avatar
St. Jude Donor '09
Originally Posted by blkbrd69
True;
My car is having this issue and it does have a 160 thermostat. Can anyone tell me where in HPtuners I need to look to change this? Thanks!
To Coolant Temperature Guage Error
Quick Reply: [Z06] Coolant Temperature Guage Error
