C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Wheel lug torque spec?
Old 12-01-2012, 08:27 PM
avenger88
avenger88's Avatar
Default Wheel lug torque spec?
Stupid question but so you guys use a torque wrench to tighten your lug nuts or do you just buzz em on? Does any one know the gm recommended torque specs?
Old 12-01-2012, 08:36 PM
jerseydrew
jerseydrew's Avatar
IIRC 100 ft/lbs
Old 12-01-2012, 08:44 PM
Gary '09 C6
Support Corvetteforum!
Gary '09 C6's Avatar
^ that is correct. I recently had this done & we checked the specs. with the GM manual...
Old 12-01-2012, 08:50 PM
Bob86gn
Bob86gn's Avatar
Always use a torque wrench so you don't warp the rotors.
Old 12-01-2012, 09:13 PM
GMuffley
GMuffley's Avatar
Originally Posted by jerseydrew
IIRC 100 ft/lbs
yep
Old 12-01-2012, 09:14 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
And in a star pattern too.
Old 12-01-2012, 09:21 PM
forg0tmypen
forg0tmypen's Avatar
Tires Plus doesn't know this. Guy looked annoyed I asked him to do it that way...
Old 12-01-2012, 09:54 PM
GOLD72
GOLD72's Avatar
Received 1,103 Likes on 717 Posts
It's why I bought a torque wrench 12 years ago when I bought the 01Z.
Old 12-02-2012, 12:24 PM
avenger88
avenger88's Avatar
nice thanks for the info
Old 12-03-2012, 03:50 PM
dmuellenberg
dmuellenberg's Avatar
Don't know if it helps or not, but I read somewhere to torque in 3 increments, 60-80-100. Not exactly sure what a 'star pattern' is - I just skip every other lug until all 5 are tightened.
Old 12-03-2012, 03:58 PM
MyOwn69
MyOwn69's Avatar
Yep - that's the "star" pattern!
Also, I, too, had heard about the 60-80-100 steps. Tried it a few times and found it to be more effort than it was worth - ultimately got 100 all the way around anyhow!
Old 12-03-2012, 05:32 PM
SmokinZ
SmokinZ's Avatar
As I understand it, the star pattern is to basically tighten the lug that is directly across the hub as the one you are working on, repeat until complete. With a 5 lug hub you end up creating a 5 point "star", like you draw in grade school.
Old 12-03-2012, 09:49 PM
Too-Fast
Too-Fast's Avatar
Yep, you got it correct.
To Wheel lug torque spec?
Quick Reply: [Z06] Wheel lug torque spec?
