C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] ABS Unit Leaking !!
Old 02-03-2013, 10:35 PM
erick_e
Support Corvetteforum!
erick_e's Avatar
St. Jude Donor '13-'14-'15-'16
Originally Posted by BEZ06
Huh???
All years and models of the C6 have Traction Control!!
Bob
Was a typo.
I meant launch control.
Old 02-03-2013, 10:57 PM
BEZ06
BEZ06's Avatar
Originally Posted by erick_e
Was a typo.
Oh!!
Im pretty sure that Launch Control is in the ECM/PCM - whatever you want to call it. I think you'll need a 2010 ECM and you'll need a 2010 VIN programmed into it.
The only guy I know of that really knows how this works is Chris White. I know he has put LC into his own older model Z06.
Check out his site for his contact info:
http://www.whiteautoandmedia.com
Bob
Old 02-04-2013, 12:06 AM
Dirty Howie
Dirty Howie's Avatar
http://i.ebayimg.com/t/05-08-C6-Corvette-Z06-XLR-OEM-Anti-Lock-Brake-Pump-Unit-Module-Complete-ABK-/12/!Bw(iNiQCGk~$(KGrHqQOKiwEwPuEU4,3BMImri4 FKQ~~_3.JPG
Old 02-04-2013, 12:12 AM
Dirty Howie
Here is one I found online. It has the exact same PN's as mine. No black module (EBCM?) attached.
DH
Old 02-04-2013, 12:36 AM
Dirty Howie
Here is one that does actually have the GM number (89060341) on it but it from a base C6 and does not have the Z0 designation like mine and the other part in previous picture.
DH
Old 02-04-2013, 10:10 AM
erick_e
erick_e's Avatar
Oh!!
Bob
Don't want to hijack Howie's thread, but thats the same guy that wrote this article here. 2010 ECM and EBCM are required to add launch control.
http://forums.corvetteforum.com/c6-t...-corvette.html
Old 02-04-2013, 02:08 PM
CanadaGrant
CanadaGrant's Avatar
DH
Just checked the numbers on my 07 Z06 unit.
GM ASM PN 15858644
GM ECU PN 15858645
*864470872940*
Old 02-04-2013, 04:29 PM
Dirty Howie
GM ASM PN 15858644
GM ECU PN 15858645
*864470872940*
Grant
Thanks for checking. Must be the model year changed something.
Anyways, I just found one from an 08 with 12K miles and it has the same PN as mine ............. so I'm getting it
DH
Old 02-04-2013, 06:14 PM
CanadaGrant
Grant
DH
Sounds good Howie. How much did it end up costing you? You might be able to re-seal the old one and sell it or keep it for a rainy day.
Old 02-04-2013, 07:22 PM
Dirty Howie
I would like to know if that port can be sealed off. Because if it can I would have tried that first.
$360 delivered
DH
Quick Reply: [Z06] ABS Unit Leaking !!
