C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] stock clutch pedal and drag racing
Old 03-10-2013, 01:17 PM
zuli
zuli's Avatar
Default stock clutch pedal and drag racing
Who is drag racing on stock clutch? I have stock clutch and have stuck clutch pedal issues. I have used Ranger method for bleeding and still have stuck pedal issue. I have been considering replacing clutch but wonder if i will have same problen with pedal.
Old 03-10-2013, 01:26 PM
Turbosixx
Turbosixx's Avatar
Nope, replace the clutch if you don't want any more issues. The stock clutch can get you by, but no matter how many times you change the fluid you still can't slip it to get the best 60'.
Old 03-10-2013, 01:57 PM
zuli
zuli's Avatar
So what clutch is the next question??
Old 03-10-2013, 02:42 PM
Turbosixx
Turbosixx's Avatar
I'm have a Mantic twin disk. A few guys are running the McLeod RXT and RPS. Some are running the Katech clutch. Any one of those are a huge improvement over stock.
Old 03-10-2013, 02:54 PM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
Either is a good choice. I love my Katech LS9X clutch, but others like yourself are having great luck with, and nothing but great things to say about, the Mantic twin disk.
Old 03-10-2013, 03:01 PM
KLRBEE2
KLRBEE2's Avatar
I have the same issues and on stock clutch. From what I understand, it's not the clutch. It's the master cylinder. Once you replace with a TIK, problem is solved...$300-400. This is what I'm going to do as well!
Old 03-10-2013, 03:13 PM
yellowzron
Banned Scam/Spammer
yellowzron's Avatar
550 to the wheels and still on the stock clutch. Until it goes out I will abuse it as much as possible. Best 60 ft on stock has been 1.9
When it goes out a twin disc will work for me just fine.
Old 03-10-2013, 03:33 PM
zuli
zuli's Avatar
I can't seem to keep pedal from sticking no matter what i do,its just a matter of time
Old 03-10-2013, 03:36 PM
zuli
zuli's Avatar
my best 60' also has been 1.9
Old 03-10-2013, 04:20 PM
KLRBEE2
KLRBEE2's Avatar
My best 60' was yesterday with a 1.6. I'm at 510rwhp bolt-ons and stock clutch. Master cylinder is the problem; it heats up on burn outs because the of the hard braking.
KLRBEE2
KLRBEE2's Avatar
I've never had it stick otherwise...ever!
Old 03-10-2013, 04:23 PM
zuli
zuli's Avatar
What does replacing the clutch have to do with sticking clutch pedal?
Old 03-10-2013, 04:41 PM
KLRBEE2
KLRBEE2's Avatar
It doesn't. A lot of ppl spend money on the clutch and still get the pedal to stick. Clutch Master Cylinder is the problem. Do a search on it and you will find that it's being replaced by a Tick!
Old 03-10-2013, 04:42 PM
KLRBEE2
KLRBEE2's Avatar
http://www.tickperformance.com/tick-...rvette-c6-z06/
Old 03-10-2013, 05:16 PM
zuli
zuli's Avatar
Thanks its sounds like it's the fix for gm's poor design. I just hope clutch is good.
Old 03-10-2013, 05:18 PM
KLRBEE2
KLRBEE2's Avatar
Yeah, I'm going this route as well. The clutch should be good at our power level and they take a lot of abuse.
Old 03-10-2013, 05:27 PM
Turbosixx
Turbosixx's Avatar
Maybe FNBADZ06 will chime in, he ran the stock clutch for a long time with good luck.
To stock clutch pedal and drag racing
Old 03-10-2013, 05:40 PM
KLRBEE2
KLRBEE2's Avatar
Yes, a lot of ppl do. Most ppl swap out their clutch in hopes to cut better 60' or to combine with higher power applications; however, I believe that you can push the car in stock or near stock for to the max and really learn it and get great performance numbers before spending money in upgrades. The stock clutch is good for a good time. I have 47k miles on mine. I don't always putt putt around with my car and at track, I hot lap as much as I can. I think money well spent goes into tires, plugs/wires, and fluids that break down with hard use. Good luck with your pedal issue. I'll let you know when I fix mine.
Old 03-10-2013, 06:03 PM
yellowzron
Banned Scam/Spammer
yellowzron's Avatar
I put the spring on the clutch for it to automatically return. I think it is sold by Lingenfelter. Sorry I don't know how to spell it.
Old 03-11-2013, 12:57 AM
zuli
zuli's Avatar
So how has spring been working for you?
Quick Reply: [Z06] stock clutch pedal and drag racing
