Z06 Late Z06 Exhaust backdate - Page 4 - CorvetteForum - Chevrolet Corvette Forum Discussion
C6 Corvette ZR1 & Z06 General info about GMs Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Advertisement
[Z06] Late Z06 Exhaust backdate
Old 03-17-2014, 12:42 AM
  #61
Hib Halverson
CF Senior Member
Originally Posted by skxf430 View Post
it came out a few months ago. Part number is 14331
http://www.corsaperformance.com/view...=14331&cfg=394
It may have been that the new Corsa X-pipe hadn't been released when I was looking for the '11 parts. Too bad. I could have saved some money, for sure.
Hib Halverson is offline
Old 03-17-2014, 02:43 PM
  #62
MTPZ06
CF Senior Member
Support Corvetteforum!
MTPZ06's Avatar
Yes, but at least you provided some data when it came to the '11 vs. '12/'13 4-cat setup using exclusively GM parts. Had you have gone the Corsa route, I'm sure someone would say the HP increase is because Corsa uses a "better X" than GM.
MTPZ06 is offline
Old 09-14-2014, 06:11 PM
  #63
Hib Halverson
CF Senior Member
Actually–and this is just my opinion–I have a Corsa X-Pipe on my C5. Corsa makes their X's different than does GM and appearance-wise I think the X-pipe in C6 Corvette exhausts is a better design.
Admittedly, I have not tested the X's against each other. My opinion is based on looking at the X-pipes I see on race cars.
Old 09-14-2014, 08:27 PM
  #64
tim414
CF Senior Member
tim414's Avatar
St. Jude Donor '12
My understanding is that 06-10 Z06 uses an H-pipe but 11-13 uses an X-pipe and 12-13 has four cats.
Also Jason Harding at Katech told me he thought backdating to an 11 midsection was a bolt on but then Justin Abbott at Zip Products told me it was not.
What we need is a photo of an 11 mid-section. Anyone have one?
add: I would think not. The extra cats are the issue b/c lengths change.
tim414 is offline
Old 09-15-2014, 02:49 AM
  #65
Ludedude
CF Senior Member
Ludedude's Avatar
I just swapped in the X pipe center section into my 2008 Z. The difference in sound is readily apparent but my butt dyno isn't really calibrated enough to notice if there is any extra power to be had.
Ludedude is offline
Old 09-15-2014, 04:08 PM
  #66
bjmsam
CF Senior Member
bjmsam's Avatar
Do you prefer the sound now with the X-pipe or before with the H-pipe? If you have the 2011 mufflers, then your input in this thread would be appreciated, as I am on the fence.
bjmsam is offline
Old 09-15-2014, 11:47 PM
  #67
Ludedude
CF Senior Member
Ludedude's Avatar
I have the 2008 mufflers with the muffler mod done and the fuse pulled on the exhaust valves so it's in loud mode all the time.
I prefer the sound with the x-pipe; it's way more exotic sounding and less motor boat lol. It's most apparent at the high end of the rpm band and then when shifting at wot...it almost crackles on the shift overrun which it never used to do. Sounds really nice.
Ludedude is offline
Old 11-16-2014, 04:34 PM
  #68
wrh3
CF Senior Member
wrh3's Avatar
I emailed Corsa about the 14331 X-Pipe and was told it would require cutting....not so. Just installed today, straight swap. I would recommend buying new donut gaskets from the dealer, it is possible to re-use the ones from your OE x-pipe but takes longer and there is the risk of damage.
Echoing some other feedback, the sound does seem to be a bit higher pitched and with less burble/pop noise (which I liked) and there does not seem to be as much heat from the center tunnel.....we'll see.
wrh3 is offline
Related Topics
Thread
Forum
Replies
Last Post
MarineMike
C6 Parts for Sale/Wanted
0
12-17-2016 09:18 AM
SRTRick
C7 Z06 Discussion
6
12-04-2015 03:13 PM
wheeljo2
C6 Scan & Tune
6
11-25-2015 11:44 PM
Jposey66
9
10-11-2015 05:25 AM
VETTEC5
C5 Parts for Sale/Wanted
10
02-16-2004 08:40 PM
Forum Jump
Sponsored Ads
Vendor Directory
  • Ask a Question
Question Title:
Description:
