[Z06] Z06 targa conversion.
Is there anything out there that specifically describes parts and installation to swap out the roof for a removable one?
I realize that most people responding will jump in here telling me how some GM engineer told them the world is going to come to an end unless one spends an arm and a leg beefing the frame up, but I already know that. Read everything that I can find.
I'm looking for detailed info on the actual top conversion itself. Unfortunately, that is much harder to find than all the conjecture about the frame. Thank you for any info.
I've read the posts of people speaking against it, but are there any instances where a frame cracked or failed due to this mod?
Id like to do it as well
Is the 427 vert frame any different then our z?
I'm no expert on vettes as this is my first one (08 Z06), but I am a mechanical engineer by degree and a big car guy.... THIS IS A BAD IDEA without the frame being specifically designed for it. People really do this?
Caravaggio does the conversion:
http://forums.corvetteforum.com/c6-c...onversion.html
http://www.caravaggiocorvettes.com/#...y/c6-z06-targa
I'll probably get a bunch of condescending "why would you do this" comments, but this is the way I see it as someone who's looking at buying a Corvette:
When you read the threads about the Z06 frame, it seems someone is BS'ing. Either the frame is not 50% stronger than a C5 frame or GM didn't actually ruin one by tracking it 30 minutes without a roof. When I fly, I stare out at aluminum wings that don't break as they flop around. Why is it that a car frame will immediately snap in half from fatigue and cause a hole in the universe if it bends a few times? Just doesn't add up. Sure, you've read the conjecture and the stories, but has anyone here 1st hand actually seen a damaged Z06 from a targa conversion?
Anyway, I can get a used one of these in the mid 30s. Throw $2-3k at the valvetrain to make sure it stays healthy and throw $1500 at the roof. If I was to ruin the frame by taking the top off so be it. I'm willing to bet the car would be fine for the expected life of the car. Car would be a fun car 4k miles a year driving normally with occasional WOTs.
A guy I do computer work for owns a ton of cool cars and for just got a mint 07 Z06 for another toy. A guy in our Aussie Pontiac club got an 06 Z06. Cool cars.
Seriously, if you can't afford to do it right, buy a Grandsport. Look at how much weight got added to the C7 for that aluminum frame to be able to handle targa and convertible tops. The Z06 frame was not designed to have a removable roof.
http://forums.corvetteforum.com/c6-z...s-begun-6.html
The car sags and twists a little. The scary part is we tested a stock car we have and it has the same issue with the roof in place. not so much the twisting but a little of the saging. We have resolved both issues and we probable added about 80lbs. of weight to the car. I will weigh the car when we are done to get the exact weight that we added.
No one has any first hand experience though. So you see comments like, "my brother's wife's mother's brother's cousin is a super smart GM engineer and says you will kill puppies and baby seals if you take the Z06 roof off.
You have to think GM engineers aren't going to give it to you straight dope due to liability. Carvagio or however you spell it can't sell you what is obviously a very profitable $11k targa conversion if you don't think you need the fancy custom brace. I'm not driving to Canada anyway.
Actually I've read somewhere someone commenting on how they couldn't feel the difference while driving the car with the top off. If it's so bad, you should be able to feel it I'd think.
Anyway, if anyone has any conversion info I'd love to check it out.
But if the frame is 50% stiffer than a C5, it should still be very stiff.
I think that you should clarify what sort of use the car will see.
I'm sure a garage queen or scenic cruiser will be just fine without a roof.
Good luck. And I hope your doors still close properly after a few thousand miles if you choose not to reinforce things.
Also you would need to figure out what "stiff" means. Torsional rigidity? tension? compression? what happens when you start removing elements that transfer the loads?
A good friend of mine did a vert and roadster conversion in 07 on the Z06. They had engineers develop a piece to strengthen the frame to get it legit. How much weight did it add and all the details I have no clue. They did develop it in carbon fiber too so there was a "lite" version.
He chopped up the roadster for a SEMA unveil and it was not well received but a cool idea none the less.
The vert was stock and essentially the 2013 427 back in 07.
Genaddi did the conversions. May be worth a call.
how many have driven a C4 with the roof removed? holy crap, wanna talk about flex!! A ZO6 with added strength is fine as shown here ^^^ . GM talks about how much stronger/stiffer the chassis is compared to earlier corvettes, why not a targa top? especially if your adding extra support. no different then adding a few hundred more HP.... you make the car handle it........
At any rate the only people who actually seem to know are the ones that wanna do the conversion for you at significant cost. Probably won't be sending me a parts list or a quote for their custom brace + shipping. Then you're back to contemplating a GS, and maybe throwing a little at that to at least make it as fast as a Z. Still cool, but not as cool as a Z with a targa roof.
Cost so much they figured that LSR would bring $150k+ on ebay...
Daffy - I too lament the fact my Z does not have a targa. However, even those few who have DIY'ed have spent well over your estimates to do it right. Most spent 4-5K and the commercial outfits charge ~ 10K. It is not as simple as unbolting the top. The mount points in the targa area have to be cut off, then new parts welded, then a replacement targa panel and hardware must be installed.
Regarding the stiffness of the frame relative to the C5 - that's irrelevant. It is that stiff with the roof in place, take the roof away, now it is less stiff and the dynamic forces on the frame change drastically when driven. All of the forces now channel through the rails and tunnel beneath the seats. The problem is in the material properties of Al vs steel. Under deflective load, steel rebounds whereas Al does not. As such, if driven hard, the frame of an unreinforced Z06 targa has the potential to permanently deform. So goes the theory. If the car is a garage queen, it would probably be fine. However, based upon your comments, you seem to want the car over the Grand Sport because of its' performance. If you drive it like it is meant to be driven, it's probably a bad idea. Further, if you ever need warranty work or are in accident with it (modified) you are hosed. If the other insurance company can blame you, in the slightest, that the modification that may make the car less stable, your goose would be cooked.
I realize you don't want the free advice but I was in your position years ago. I decided the risks were too great. The car is worthless if the "what ifs" do happen. Not worth the headache to me.
