C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Sound deadening your interior...?
Old 10-16-2013, 11:25 PM
LS7 BUD
LS7 BUD's Avatar
Default Sound deadening your interior...?
I was wondering to the guys that have sound deaden their C6Z interior how much did you use...? What type did you use and how well did it work...? I don't like how noisy it is inside the car... Also would say Dynomat help with the heat from the exhaust coming in the interior...?
Old 10-17-2013, 12:00 AM
Rupert pupkin
Rupert pupkin's Avatar
Dynomat only reduces sound coming in.. Not heat..
Old 10-17-2013, 03:02 AM
colts95ta
colts95ta's Avatar
I did my car while I did the stereo.. Noticeable difference. I don't recall how much I used but it is not light weight if you are one of those people that are always fretting over adding weight. The box I used was around 20 lbs but well worth it.
I also just recently did under the center console when I put a shifter in. According to their website it does help with heat also. I'm sure that over time it will still get warm but we will see...
Here is their website:
http://www.dynamat.com/products_auto...roduction.html
Old 10-17-2013, 07:02 AM
kotik
kotik's Avatar
i did exotic vette, but mainly for heat. It's a great product, but hte whole interior has to come out. Before you order make sure they send you install directions, I never got them (been 2 months since i last asked them, and still don't have them). Kit comes with 24 million pieces, so it's good to know which goes where.
Heat is reduced, A LOT!
noise, well you main noise is coming from the trunk, but i didn't put stuff there. It got noticeably quieter though
Old 10-17-2013, 07:16 AM
JwT
JwT's Avatar
I just finished doing the rear forward to the rear of the seats. I bought a box of Eastwood dynamat for heat and then covered that with 1/4 inch foam sheets from dynamat. I also stuffed the wheel wells with fiberglass and reassembled. The result is fantastic the low drone is nearly gone and the cabin is very quiet. The heat in the rear has been greatly reduced. This winter I plan to pull the seats and finish the front. All in all its a bit of a pain but well worth doing.
Old 10-17-2013, 09:24 AM
bgad
bgad's Avatar
I used the kit from Vette Nuts. It came with the pieces clearly marked and cut to exact size. I got their deluxe 2 part kit and it weighed almost nothing. It made an enormous difference in the sound and the tunnel is not hot any longer.
Old 10-17-2013, 09:41 AM
Iceman427
Iceman427's Avatar
RAAMmat and Ensolite is what you need. Get it here: http://www.raamaudio.com/categories/...Foam-Products/
I did my whole trunk area, behind the seats, and center tunnel. Its a big difference in sound and heat.
Old 10-17-2013, 10:58 AM
LS7 BUD
LS7 BUD's Avatar
Thanks guys
Old 10-17-2013, 11:59 AM
forg0tmypen
forg0tmypen's Avatar
With the exhaust closed, the Z06, even my 06 model is very tolerable. Its a Z06 after all, not a Lexus.
Old 10-17-2013, 03:41 PM
LS7 BUD
LS7 BUD's Avatar
I have a 06 C6Z and I would like it just a bit quieter inside the cab when my exhaust is open...
Old 10-17-2013, 07:28 PM
Buddy A
Buddy A's Avatar
I did the same product, but I also did my doors. Huge difference. When you close the door there is a solid thud now.
I even went wild and put the exotic vette product on top of the Raamat and ensolite.
To Sound deadening your interior...?
Quick Reply: [Z06] Sound deadening your interior...?
