[Z06] WCCH heads 12k miles **video**
#81
Has anyone sent in their heads with measured wear and received the original heads back with their fix. Did they identify where the side load was coming from and was it corrected. I keep reading the fix and only the mention of the bonze guides and SS valves. When you change more than one variable how do you arrive at a single part error determination? Also again for the zillionth time the OEM guides have copper in the mix giving the same thermals as bronze with a greater wear factor do to hardness.
Does anyone know ?? Please don't say , call them and ask. I would have if I had my heads worked on..
#82
Supporting Vendor
Received 1,012 Likes
We do believe (due to personal experiences/lessons, ect...) that our aftermarket PM valve guides are the way to go. We truly do believe that they are superior.
Also Propain is correct, as a paying sponsor it does get old hearing everyone just repeater the same thing over and over weather from their own personal experience or just repeating that of others (which is sometimes the case on any internet forum). The point of my post was not to upset or turn away potential clients/customers but to let others know that there are other shops capable of working on LS7 heads with very successful results.
#83
For many of us, yes it is good to see videos like that one.
For others of us, it's a huge disappointment.
Oh, and Howie, don't sweat it, because many in here appreciate your videos.
At least you aren't claiming bone stock when you're not.
Have a look at what is referred to as bone stock.
http://forums.corvetteforum.com/c6-z...fast-list.html
I was co admin of that list back in 2007 when it was put it together, indeed, it was put together at my suggestion and Ranger, knowing that at that time I was making the initial passes in my own car, recommended that the listing be modeled along the C5 Z06 Fast List, and his is the first post in it outlining the rules.
On a side note, I still recall his early attempts to get his driving dialed in.
http://forums.corvetteforum.com/c6-z...-125-69-a.html
We kept that listing for years, I was running my own car in Western PA, him at MIR, Capitol, and occasionally at ATCO. He was setting records, I like many other new owners back then, was just learning, I recall his advice and encouragement though.
I would make the updates and additions to "The C6 Z06 Fast List" each time a member wanted added to it, and checking across this forum for prior posts and even other internet forums to determine the authenticity of bone stock claims. When I first saw some of the present day or more recent claims, I tended to think that it was 4.10 gears. These were unlikely back then, if not impossible, as I think that RPM transmissions was among the first to make them available around 2010 or 2011. But today I still would not put that past some of the claims made now, as they became available for the Z06 well after the start of that listing. But there are other methods as well.
I busted people all the time making bogus bone stock claims.
Let's just say, that to the letter of those rules conceived back then and still in effect to this day, "engine balancing" doesn't apply as showroom stock or bone stock.
For those who want to know what engine balancing is, and work on the short block is, and why it's not bone stock, and what advantages it offers what it entails, I encourage you to look it up.
But it is good to see that there is a hotshoe from hell amongst us.
Take a look at the link I sent you.
Anybody else wants to see it PM me.
Oh, and while I was admin of that listing, I never expected it to, but that work, made it all the way to Wixom.
Take a look:
http://forums.corvetteforum.com/c6-c...ld-center.html
Take a look:
DH
#84
That was not my intention.
My question for you would be this. Since the OEM guide was PM, and it is a known weak link, then why use another PM guide?? Be specific here, why not bronze, and why is your guide better in your opinion? What proof do you have that your method is superior?
No seriously kiddies, doesn't it make more sense to take an approach like this rather than attack him? Maybe he's right, none of us really know at this point.
#85
Received 8,928 Likes
Well, Howie, you don't know if it is true or not. Testimonials, such as those you have given on this issue repeatedly, are not scientific or engineering fact.
Now this is what we call a testimonial. It has no basis in scientific or engineering fact. All it means is that Howie hasn't blown up his engine yet.
Curious as to the validity of his claim, I took a look at one of his data-overlaid track videos. Each lap was mostly run in 3rd gear between about 3500-5200 RPM, with a couple short bursts up to about 6100 RPM (in 3rd), a start-finish line crossing at 6200 RPM in 4th, and one 3-4 upshift at 6700-6800 RPM. Except for that last part (upshift) all that is not very taxing for any LS valvetrain...
There isn't much scientific proof about your statement either. I don't claim any scientific proof about my claims because I don't really know what is taxing or not.
Bill
#86
And seriously, can't we get over the cheap shots and personal attacks? I respect everyone's opinion on this, I just don't see why we can't express it without the insults. I disagree with some here as to the best method of repair, but at this point we don't know who's right here.
Personally, I went the WCCH with OEM valves based on my research. I also know another method may come along that is superior, and with time we will all learn more. Aid if I have to pull the heads again in a few years and do it all over using a different method, so what, I've saved my engine and I'm ok with that.
OK, getting off the soap box now ;-)
#87
Well I have analyzed most, who sit back and analyze others, who actually do run on the track. And wouldn't you know it but sometimes the track dictates short shifting (although most would not consider 6800 rpm short shifting). Sometimes when you are looking to set up for a long high speed sweeper you can't watch your tach to see if you have squeezed the last 200rpm out of it. Now I hope these same couch racers watch my video from ACS where there are 3 straight aways (two second gear shifts and one third gear shift) with no eminent turns where you can actually watch your tach and run it right up to redline
DH
DH
I've considered adding an aftermarket rev limiter that I could turn on at track events to limit the accidental redline runs, since as you say you really can't look down at your tach going into a corner.
#88
I have no desire to push my car to the limits at track events, just no reason unless big $$$ are involved.
#89
As long as you save your engine, you've accomplished that which needed to be done.
Different people are going to decide upon different ways to do that.
Nothing wrong with that approach either. It's your property to do with as you see fit.
If you have your own copy of HP Tuners, you can load a tune with a lower rev limit if you want, and then go back to your current tune with your rev limiter set where it currently is.
#90
While everyone is all in arms over valve type in this thread - please PM me what valves you went with and their respective advertised/actual weights so I can update another thread in this sub-forum.
Every forum has a few people that don't see eye to eye, but for the benefit of the whole it would be nice to see more fact (such as but not limited to the video posted, more info on PM versus bronze, guide install height, etc.) than people throwing rocks.
Some people get caught up in finding the absolute best option available and don't realize there are other viable options that are an improvement over the OEM hand we were dealt. There's always more than one way to skin the proverbial cat.
Carry on.
Carry on.
#91
I was thinking about a launch controller / rev limiter but getting my own copy of HP Tuners isn't a bad idea either. I do want to get a launch controller at some point and I know that some have a rev limiter built in.
#92
Thanks, I'm aware of that and I don't have HP tuners. My thought was that I could adjust down for track, then back up for a dragstrip as needed.
#94
Late Model Domestics
#95
I know what I saw in Howie's video was not taxing on the valvetrain, save the one 3-4 upshift at 6700-6800 RPM (per lap). I think that would be a common assessment amongst anyone that has moderate understanding of valvetrains upon viewing that video. I only pointed it out because he was touting as a proof of concept, which to me seemed to be about equal bragging about how a particular 3/4 ton pickup could pull a 4,000 lb trailer. My Dodge Dakota can pull a 4,000 lb trailer. It does not take a scientist nor engineer to assess that relationship. However, it does take one to assess the long term damage, if any, associated with the type of valvetrain modification that Howie was trying to promote.
#96
Curious as to the validity of his claim, I took a look at one of his data-overlaid track videos. Each lap was mostly run in 3rd gear between about 3500-5200 RPM, with a couple short bursts up to about 6100 RPM (in 3rd), a start-finish line crossing at 6200 RPM in 4th, and one 3-4 upshift at 6700-6800 RPM. Except for that last part (upshift) all that is not very taxing for any LS valvetrain... LS1-2-3-6-7-9, so it is hardly a proof-of-concept validation for heavier valves/springs.
Nobody expects an additional 7.3 ounces of total valve weight to affect your top speed, serious valve float aside
First, I appreciate that you took the time to watch my video.
This was my first time at the track with my new Aim Solo DL. So you don't see any other overlays from all the track days I have done. Believe me I get to 7K plenty and hit the rev limiter twice that I can remember.
On this track there is only one place where you can get to redline … where you note the 3-4 upshift. It also happens to be where you setup for turn 8. You have to be watching the track ahead. I upshifted by feel and necessity, not by watching the tach.
Be sure to watch my future video on tracks with straight aways where I can watch the tach like at ACS. You will be seeing plenty of 7K shifts.
I hope you can remember this post of your then.
DH
#97
I've got 5 track days on my wcch stage 2 heads with a mid size cam. .660 lift. I have hit the rev limiter on maybe a half dozen times (some on the dyno). I've run to 7000+ rpms about 150 times on the track. I know that doesn't mean much, just my experience so far. I hope the wcch shop is right about the combo.
#98
Howie's max oil temp after 9 laps (14 minutes) was 235F. Based on that alone I don't think he was stressing the engine too hard, but I also think that is irrelevant as to proving the long term validity of heavy valves.
You are looking at a couple of sessions on one track. I can't wait till I go back to Auto Club Speedway and the car gets redlined 2 time in 2nd gear, once in 3rd and even once in 4th (156mph) on each lap. Sorry at this track, WSIR, the only place where you can redline is that one 3-4 shift and its easy to leave that last 150 rpm on the table when you see the end of the track approaching quickly.
Will be waiting for your comments then.
DH
#99
DH
