C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] E85 fuel pump
Old 03-29-2014, 11:00 PM
Maligator
Maligator's Avatar
Default E85 fuel pump
how many are running E85 on the stock fuel pump without a failure?
Old 03-30-2014, 05:38 AM
EX1
EX1's Avatar
You won't find many. E85 eats the stock pumps up. If you want to make the switch, search the numerous threads on the subject. If you are making decent power, you may need to invest in larger injectors as well for the increase in volume.
Old 03-30-2014, 10:27 AM
HeadTurner
HeadTurner's Avatar
Stock pump no issues. .about 1.5 years. . 576 to back tires
Old 03-30-2014, 11:38 AM
Matt-P
Matt-P's Avatar
Stock pump here to, 2+ years without issues, 606 to the tires
Old 03-30-2014, 11:56 AM
LS9Drew
LS9Drew's Avatar
Your best bet is prolly to do the flex fuel kits people are doing lately and only running e85 occasional to help it last longer. Matt has done more than a few around here and gonna do that on mine in a few months.
Old 03-30-2014, 05:26 PM
EX1
EX1's Avatar
interesting that two here have had good luck. A few shops won't even make the switch unless the customer switches to a pump rated for ethanol. People using flex fuel systems are running regular premium fuel too so the life of their pumps will of course be longer.
Old 03-30-2014, 07:17 PM
Halltech
Supporting Vendor
Halltech's Avatar
St. Jude Donor '09
Stock fuel system=608RWHP/535lb/ft, since 2008 and 19,000 miles. First Z06 to run e85, built to Katech specs.
Our Katech motor has never needed any changes except the 65lb/hr injectors.
Methanol is corrosive and a rubber eater, not Ethanol.
Also ran e85 in our 2010 CTS-V making 610 RWHP for 3 years, no fuel pump change. 85lb/hr injectors.
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
www.halltechsystems.com
Old 03-30-2014, 07:19 PM
Halltech
Supporting Vendor
Halltech's Avatar
St. Jude Donor '09
Three. Stock fuel system=608RWHP/535lb/ft, since 2008 and 19,000 miles.
Old 03-31-2014, 11:24 AM
BgBoost1
BgBoost1's Avatar
I just started my 4th year on the stock fuel pump and E85. Not near as long as Mr. Hall's record but its going strong!
Old 03-31-2014, 12:05 PM
Maligator
Maligator's Avatar
Crazy how people are at both ends of the spectrum!!!!!!!
Old 03-31-2014, 03:14 PM
rustybridges05
rustybridges05's Avatar
the minimal cost i invested to upgrade the pump and lines didnt make much sense to not go ahead and upgrade. id rather have too much fuel than not enough
To E85 fuel pump
Quick Reply: [Z06] E85 fuel pump
