[Z06] LS7 Spintron Testing Request and Donation Thread
#201
#204
Id like to see what effect a roller rocker has on the valve train control.
Weren't there a couple of guys willing to send in some RR's?
What about those "endurance" cams?
Id like to see an endurance lobed cam (milder than the K501) with a Ti exhaust valve beehive springs and RR setup on the bill.
#208
I think Michael_D knows someone who can provide an HS roller tipped rocker to use with stock setup and vert_c6 can source an endurance cam.
So test 3:
Stock cam, springs, valve
HS roller tip rocker
And test 4:
Torquer cam,
Ferrea valves,
endurance cam
Beehive sprigs
Both tests have baselines for their respective parts
If everyone is ok i will add these two tests to the OP or Michael_D or VertC6 if you feel like these setups aren't right or you can get the parts let me know.
#209
Thanks to Michael_D we are at $850! There's still a few people who have said they will donate but haven't yet, one is having PayPal issues and some others just haven't checked back yet. Soon we should be over our first goal of $900 and then once the next two tests are agreed upon, I'll will send this to Jason to get a new quote on our second goal to run all 4 tests! Progress is being made!
#211
Just remember that Jason (and most of the people at Katech) are out of the office now at their annual customer track event, Track Attack. So he's probably not going to be back in the office until Thursday and then will be playing catch up for a few days so be prepared to expect some delays on replies from him until he gets caught up on things
#212
The endurance cam and a roller tip would make for two different combos. So that would give us a total of 4 different setups.
So test 3:
And test 4:
Torquer cam,
Ferrea valves,
endurance cam
Beehive sprigs
So test 3:
And test 4:
Torquer cam,
Ferrea valves,
endurance cam
Beehive sprigs
For test 4 you said "Torquer cam,Ferrea valves,endurance cam,Beehive sprigs" Is the Torquer an endurance cam?
Would we put RR's on that setup?
#213
The advantage of the roller tipped rocker is, at least theoretically, less side load on the valve stem and valve guide (which should = less valve guide wear).
#214
Ok great but the stock setup had little to no bounce at all so putting the RR's on it might not show any improvement. Maybe the benefit would be in a situation that needs more control? Am I correct in my thinking here?
Ferrea valves
Endurance cam
Beehive springs
Stock rockers
So you don't think the RR on the stock setup would yield valid data?
#215
There are people installing YT roller tipped rockers on an otherwise, completely OEM engine. For that reason, I think it would prove most beneficial to start out with an OE valve train, then install the heavier rockers. That would eliminate the math and / or theoretical component that so many on this forum have difficulties with.
Or, if the testing contributors don't really give a damn what this pig headed demographic thinks, then we could just install the CHE and HS (or YT if I can find some) rockers on the baseline set up, after it's ran with OE rockers. Personally, I really couldn't care less, as long as three back to back tests are done 1) OE rockers 2) CHE rockers 3) Roller tipped rockers. I can do the math with each of them and extrapolate into a % based formula that would at least provide some degree of estimation with respect to nose weight.
But; if these tests are done with the lighter Ferrea valve and good springs, I suspect the test will need to be ran up to 7800, or maybe even 8000 to see when valve goes from bounce to float.
Now that we are over the $900 threshold, how bout some of you other interested folks walk to work for a couple days, save that money you'd spend on a tank of gas and double down?
#216
Would the CHE rockers even be necessary? It's the same rotating mass with a bushing vs a bearing... unless the theory is that instability in the trunnion bearing leads to valve instability (no idea, just shooting in the dark).
But I agree that at the very least a back to back between the OEM rocker and a roller tip on an otherwise stock valvetrain would be very interesting, and that the stock valvetrain would be the place to test it (most susceptible to stress/load).
#219
#220
If we do raise enough funds I will call Kip back at cam motion and he will donate one of his cams for testing. Find out from Jason the hours evolved to swap cams after the Ferrea valve and PSI springs are tested with the torquer.
