C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] what causes wiped cam lobes?
Old 08-15-2014, 12:46 PM
spy2520
spy2520's Avatar
Default what causes wiped cam lobes?
Does this happen on stock and modified engines?
Old 08-15-2014, 01:03 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Yes it happens on both.
Bad cam core, incorrect cam installation, bad lifters, incorrect oil weight, oil break down, excessive spring pressure, incorrect valve train setup.
Old 08-15-2014, 01:17 PM
Mark2009
Mark2009's Avatar
Add: incorrect break-in procedure.
Old 08-15-2014, 02:53 PM
spy2520
spy2520's Avatar
Mine doesn't look good. Haven't pulled the valve covers so I dunno what If anything has been done to the heads.
The lobes don't look scored or chewed up but they are definitely worn down where the lifter wheel rides.
Old 08-15-2014, 03:18 PM
Undy
Undy's Avatar
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,095 Likes on 578 Posts
GM has a continuing problem with "soft" cams
Old 08-15-2014, 04:21 PM
spy2520
spy2520's Avatar
That sucks
Old 08-15-2014, 04:51 PM
phipp85
phipp85's Avatar
My stock cam had scuffed/scored lobes and most of the lifters looked the same.
Old 08-15-2014, 04:55 PM
spy2520
spy2520's Avatar
So am i looking at cam and lifters (if the top end is stock)? I think i already have a cam that would work.
Old 08-15-2014, 05:53 PM
Michael_D
Michael_D's Avatar
What are looking at? How can you see the cam lobes if you haven't even pulled the valve covers?
Old 08-15-2014, 06:09 PM
spy2520
spy2520's Avatar
Oil pan is off.
Old 08-15-2014, 09:17 PM
Michael_D
Michael_D's Avatar
Jezzzuuss, you're ambitious! I take it you pulled the engine? Out the top or bottom?
Old 08-15-2014, 11:20 PM
psp6158
Support Corvetteforum!
psp6158's Avatar
Mine too,they looked like they had 200,000 miles, not 5000...
Old 08-16-2014, 06:28 AM
Undy
Undy's Avatar
Here are a couple pictures of my OEM cam's "soft lobes". The lifters looked good considering. I did replace all the lifters and rockers.
Old 08-16-2014, 10:49 AM
spy2520
spy2520's Avatar
That is pretty much what mine looks like. I'll try to get a pic. And the motor is still in the car.
Old 08-16-2014, 11:08 AM
Michael_D
Michael_D's Avatar
Now I'm really curious..... How about you provide some details instead of spoon feeding? Do you have a coil over set up, or did you pull the spring, or...??
Old 08-16-2014, 11:35 AM
spy2520
spy2520's Avatar
Dropped subframe, pulled leaf spring. Takes surprisingly little effort. I have a 2 post lift at my house though.
Old 08-16-2014, 12:15 PM
Unreal
Unreal's Avatar
Pulling intake manifold/valley plate also gives a good view of most of the cam and would be easier to check for most people.
To what causes wiped cam lobes?
Old 08-16-2014, 01:00 PM
spy2520
spy2520's Avatar
I didn't drop the pan to look at the cam, i just happened to see it while the pan was dropped.
Old 08-16-2014, 01:13 PM
Michael_D
Michael_D's Avatar
How do you support the engine when you drop the cradle?
Old 08-16-2014, 01:20 PM
spy2520
spy2520's Avatar
I have a "strut tower" engine support but i didn't think it would work on the vette. I have extremely tall jack stands holding it up currently. I think they go from 5'-8' or so. Same idea as using jack stands on the ground i guess, but with the added luxury of being able to stand under the car.
Quick Reply: [Z06] what causes wiped cam lobes?
