[Z06] what valve spring tool for ls7
Actually there is nothing but.
1. There is plenty of info in the thread to make an informed decision.
2. You appear ready to discard all that based on the word of someone who works on cars everyday, like the Chevy techs that can't change the oil in an LS7 or the private mechanics who put the lash caps on the exhaust valves (or leave them off altogether).
You know that rocket scientists never actually build the rocket, right?
ian08,
Sorry your thread was dragged off track. There have been several informative posts so far with recommendations from guys who actually work on cars. I thought it might be interesting to get some more input from professional mechanics. It certainly was not my intention to start yet another Z06 forum pi$$ing match.
Hope you find the information you're looking for. You might ask the mods to delete the last several posts.
My point on this and several other threads are three-fold:
1. there is plenty of info available to make your own decisions; correct decisions (rather than relying blindly on others). The OP got his in this one.
2. 'pros' are often wrong.
3. If you're going to own one of these cars, you should plan on learning and performing most of your own maintenance.
Sorry if the bedside manner needs work; I usually shoot from the hip
Uh, the LS7 ratio is 1.8 dude.....
And that tool looks like a PITA. The comp double spring tool works great
I've tried them all. None will work properly.... the LS7 is 1.7 ratio vs 1.6. You risk damaging the valve stems w/a 1.6 tool.
Best bet is old school crank style with all corners & sharp edges carefully hand chamfered to prevent the spring from being nicked, dented, or scratched.
The Comp tool works, but you do have to pay attention to what you are doing. Don't just run the bolt down without watching for any binding action. Also make sure you have it bolted down snuggly. Not so tight you pull the threads out of the pedestals, but pretty snug. If I were to be doing a lot of LS7 head work, I'd definitely look at that LSM tool. If the heads are off, I use a large spring compressor that has an adjustable retainer foot. It works great for breaking down springs quickly, but sometimes I want the heads to stay flat on the bench, like when blue printing spring height. Sometimes I'll use several different shims, cups, retainers, locks to get the height where I want it. When doing that, It's nice to not have to constantly move the head around.
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,095 Likes
I was thinking of modifying my Comp Cams tool to work a bit better. I was going to run a welding bead on the inner side (closest to the pedestals) of the plate that contacts the retainer. I'd then grind it down till both lips contact the retainer at the same time to allow for a more even depressing of the retainer. I haven't made up my mind if I want to mess with it yet. It's not a daily use tool.
I'd weld up the threaded boss and redrill it at the correct location and angle, but that will require some machinist skill. Maybe some heat treat too.
Think of making that arm that reaches from the pedestal longer, just like the LS7 rocker is longer. Then everything lines up. The screw needs to be parallel to the valve stems.
BTW... even though the Comp Cams assembly's reach is a bit short due to the increased rocker ratio it's still parallel with the valve stem, just offset a bit towards the rocker pedestal. The weld job would still be a great improvement. You could check for the correct contact with a feeler gauge.
#33
Oxy/acet using grade 5 (45%) silver solder and a 1/2" long piece of coat hanger wire on each side. I use the stuff all the time with ferrous fittings. Then file the coat hanger to get even contact on both sides of the retainer. It'll take about 1/2 hour to do. I'll do it during my next wiggle test.
#35
#37
[QUOTE=MTPZ06;1596841059]Unfortunate that it took like 4 years to clear that up, right?[/QUO
Ha! Better late than never ..... I was wondering if anyone would see that.
