[Z06] Stock Replacement Lifters
Here is what I am going to doing. I am going have my heads done by American Heritage. I will keep the cam stock but I want to replace my lifters with an direct OEM replacement. On a different post I asked about Comp Cams lifters, replies stated there are better lifters. I am not familiar with the different lifters outside of Comp Cams, if you could provide part numbers for the different lifters that would be a direct replacement for the stock lifters that would be great? Someone said COPO , is this a GM lifter?
If youre having your heads done by American Heritage, just order them through them. That's what I did. They came the same time as the heads and were priced better than I could find anywhere else.
Katech sells the High speed lifters. Was told they add 200rpm in terms of safety for valve bounce at high RPM. They are on their website. But for what you're doing just OEM will be fine.
New ls7 lifters are fine and $140 for a set of 8. Just put new OEM lifters in it.
If not having any noise why remove them from the bores at all?
Stock lifters seem fine for a stock cam, great match.
Only when going up on lift does it seem like you need a slightly better bleed down control due to higher spring tension.
Even then stock lifters are great for most people. I talked to a lot of places and shops, and landed up with stock ls7 lifters on my build, and budget wasn't an issue. No issues at all with stock ls7 lifters, but my cam is also fairly mild, 230/246 LXL LXL.
We have been told down here in new zealand that Johnson lifters are the best made USA brand lifter , and i must admit i have never had any problems with dozens of small block chev and ford motors we have built over the years , and they are making a special lS 7 lifter with a minute hole squirting the roller , my local supplier has them , but the GM delphi lifter is still a high quality item by all accounts
For me to get the stock LS7 lifters they had to be purchased individually and would have ended up costing $337...go figure.
Cheers, Paul.
Strange. Buying the ls7 individual they do come out to be pricey, but there is an 8 pack for $140 that saves a lot.
Cheers, Paul.
12499225 shows as LS7 lifters and can be found for $120. Are you sure those are the ceramic ball ones? I think those are the standard LS7 lifters.
Caddy ceramic ball racing lifters are $300 or so
GMP-88958689
GMP-88958689
So what you're saying is you believe PN#12499225 and PN#12576400 are probably the exact same lifter? If so, I don't think I'll spend a lot of time arguing about this with you because you might well be right
Cheers, Paul.
I think the 225 is just the GMPP number for the 16 pack of ls7 lifters (or newer LS style since they all became the same). The Other part that is $300-350 is the ceramic ball caddy race lifter.
Supporting Vendor
Received 1,012 Likes
If you needing a set of the GM LS7 lifters give us a call. We keep them in stock and sell them at a very reasonable price point.
http://www.americanheritageperformance.com/
310-326-2399
310-326-2399
