C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Tested my injectors
Old 03-08-2015, 01:19 PM
Hib Halverson
Pro Mechanic
Hib Halverson's Avatar
Received 1,135 Likes on 592 Posts
Default Tested my injectors
Anyone who is calibrating ("tuning" or "programming") their LS7's ECM is likely doing it in the interests of improving performance and drivability along with ensuring the engine gets good fuel economy. When you're calibrating for improved performance, you're often setting air/fuel ratios closer to "lean limits" and, if so, whether or not all your injectors are all flowing the same amount of fuel becomes critical.
I've been using RC Engineering in Torrance, California for injector flow testing, cleaning and consultation for about 25 years. The folks at RC have been doing fuel injector, flow testing, cleaning and modification for about 30 years. Founded in 1969 by the late Russ Collins, RC Engineering began as a maker of competition parts and as an engine builder of Honda and Suzuki motorcycle engines for drag racing.
In mid-'80s, observing the popularity of sport compact cars in drag racing and road racing, Collins, using skills gained in building four-cylinder motorcycle racing engines, began building race engines for the developing sport compact car racing movement. Most of these small four-cylinder engines were electronic port fuel injected and Collins soon found that their fuel injectors could be a big restriction. When he started researching injectors, he found that sources of information at Toyota, American Honda, Nissan and other Japanese car makers couldn't (or wouldn't, as the case may have been) furnish information on injector flow capacity.
Russ Collins needed to be able to flow test injectors and soon found himself designing equipment necessary to do that. By the end of the '80s., Collins was the go-to guy for racing electronic fuel injectors. Not only was he flow testing and modifying some injectors but he also began selling a line of high-performance injectors, many of which were the superior rotating disc injector design initially developed by Lucas Aerospace. By the early-'90s, his business had expanded into injector sales and service for American cars and one of the first Corvette engines to become popular for RC Engineering, upgraded disc injectors was the LT5, the 5.7-liter DOHC V8 in the '90-'95 ZR-1s.
In 1997, put a set of RC injectors in a 1995 LT5 and those same 16 injectors are still in service 18 years later. Every so often, I've pulled them out for inspection and testing and they pass with flying colors. Since then, in 2006, I installed RC Engineering disc injectors in my 2004 Z06 and, in 2012, in the modified 3.8-liter V6 in my '01 Camaro. In both cases, drivability, especially throttle response, improved because of the disc injectors superiority over older-style stock GM injectors and that the flow balance of RC's injectors was much better than stock.
Sadly, in 2014 Russ Collins died, but his RC Engineering legacy continues. The Collins family still operates the business with John Welfringer as Manager. Today, RC remains a top electronic injector sales, service and consultation source in the performance aftermarket with Worldwide sales and the most sophisticated testing equipment in the injector service business.
Recently, I was changing the calibration of my LS7 and, in data logging with HPTuners VCM Scanner, looking at fuel trim values, I noted the right bank of cylinders was running more rich than was the left. Sometimes this just happens as a function of the way air flows into the intake manifold or because of slight cylinder-to-cylinder differences in distribution but then, sometimes it's because the injectors are not close enough in injector-to-injector flow rates.
Wanting to cover all bases, I decided to pull the injectors for testing. On my next trip into the greater L.A. area one Thursday morning, I stopped off at RC Engineering and had them flow tested. Injector Technicians Wayne and Keoki San Miguel (yep, they're brothers) quickly tested my injectors in RC Engineering's "Certa-Flow 2000" injector flow test machine. Sure enough the "system balance" was 4.8 which means the highest (419 cc/min at 4 bar fuel pressure) and lowest (411.4 cc/min) flowing injectors differed by 4.8%. Ideally, system balance should be 1 to 1.5. A near 5% difference may not make a noticeable difference with a stock engine, but with one where you're calibrating for exactly .86-lambda at wide-open-throttle, you're going to see that difference, especially in a case like mine where my Innovate Motorsports wideband O2 sensor is only on one bank on cylinders. In that case, you want to make sure that the other bank of cylinders is not more lean than the bank your calibrating.
After looking at the flow test data, RC's John Welfringer suggested that I leave the injectors with his guys for a five-hour session in one of RC's ultra-sonic cleaning machines. Since I was headed back to my shop in Goleta, 150 miles away, he said they'd UPS the injectors to me that evening and I'd have them the next day.
Sure enough, Friday evening, UPS dropped of a box from RC Engineering...love the quick turnaround on testing! Inside were my injectors and a test data print out saying that, once the injectors were cleaned, the system balance (421 cc/min, high, and 416 cc/min, low) was a far better at 1.2. What an improvement! During a road test with HPTuners Data Scanner recording engine controls data the long term fuel trim values were now closer together. It's a safe assumption that, at wide open throttle, the bank-to-bank A/F was now closer, too.
So...why not an injector change to RC's disc injectors? One reason is my engine is not yet modified to the point it needs a higher flowing injector. Secondly, the advantage of disc injectors is not as great as it once was because the Bosch pintle injectors used in the LS7 have much smaller pintles and, thus, can react quicker to changes in pulse width. Third and most important, there currently are no disc injectors available in the small package size used by GM on LS7s.
Want more information? Visit RC Engineering's web site which has a wealth of electronic fuel injector and electric fuel pump information.
carpe dm (03-31-2016)
Old 03-08-2015, 01:24 PM
AZDANZ06
AZDANZ06's Avatar
Great write up.
Old 03-08-2015, 04:36 PM
RFZ
RFZ's Avatar
my wide band is in right bank. when logging i have stft/ltft difference between banks.[ don't recall which is richer] another possibility is different reading o2 sensors. sometime in future i will be doing some work on the car and i will try a couple of different things. i will take base log, change injectors from one bank to the other, same with o2's. it will be interesting to see results.
Old 03-08-2015, 05:16 PM
Too-Fast
Too-Fast's Avatar
How many miles on your car and have you ever used any kind of fuel additive like Techron?
Old 03-08-2015, 06:48 PM
Dirty Howie
Dirty Howie's Avatar
On my C5 built motors we used flow matched injectors. Surely this is a smart to do when leaning out the fuel mixture. Certainly many motors have geen lost due to some cylinders running too lean after tuning.
Thanks Hib
DH
Old 03-08-2015, 10:46 PM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
Thanks Hib
DH
It's why I haven't added a FAST intake. I know I'd want flow matched injectors with it.
Old 03-11-2015, 11:36 AM
Hib Halverson
Pro Mechanic
24151
I've used Red Line Complete Fuel System Cleaner but I'm thinking maybe not often enough.
Old 03-11-2015, 01:33 PM
Too-Fast
Too-Fast's Avatar
24151
Thanks for the feedback, I have 2,100 miles on mine and I use Techron about every 800 miles. Yeah I know, not too many miles.
Old 03-11-2015, 03:50 PM
AZDANZ06
AZDANZ06's Avatar
I run Chevron 91 Octane in my Z exclusively, already has Techron in the fuel.
Old 03-11-2015, 08:10 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Same here, but I also add the big bottle of techron about every 3-4 fill-ups.
Old 03-11-2015, 09:48 PM
Z06Ronald
Z06Ronald's Avatar
Thank you for sharing your experiences with us, Hib!
Old 03-13-2015, 06:50 PM
40YRW8
40YRW8's Avatar
I had mine flowed at Nelson Automotive here in Tucson. My spread was 1.4% not counting one that was lazy by 3.6% I had them all cleaned but the values didn't change at all. The lazy one was replaced. Just for fun I installed the richest injector in Cylinder 8 and worked forward to the leanest in Cylinder 1 since as far as I know the farther to the rear of the block, the hotter the cylinders run.
Gary
P.S. Thanks Hib for years of bringing science and reason to a sometimes contentious and snarky place.
Old 03-13-2015, 10:29 PM
Hib Halverson
Pro Mechanic
Originally Posted by 40YRW8
(snip)
The CF?
"Contentious", "snarky"???
Surely you jest.
Old 03-14-2015, 08:50 AM
Undy
Undy's Avatar
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,090 Likes on 574 Posts
I'm running a matched set of new Bosch 60# LS2 injectors from Fuel Injector Connection.
Old 03-16-2015, 08:52 AM
AzMotorhead
AzMotorhead's Avatar
Good write up but your math is off.
411.4 to 419 is only 1.8%
Old 03-16-2015, 07:40 PM
HOXXOH
HOXXOH's Avatar
Received 2,058 Likes on 1,503 Posts
Yeah, I noticed that too. It must be something in the Peoria water.
But other parts of the write up and replies got me checking about WOT LTFT and wideband readings that might not show if I'm running too lean. It's already consumed several hours of my day and I'm now more confused than enlightened. It's not the first time Hib made me do more thinking and research.
Old 03-30-2016, 04:01 PM
dkz
dkz's Avatar
I had mine flowed and cleaned.. I thought they would all be in "Fair" shape at only 50k. I can't really feel anything from the butt dyno but it does feel smoother on the low end and picks up speed faster with less throttle.
To Tested my injectors
Old 03-30-2016, 07:30 PM
Dirty Howie
What did this service cost ??
DH
Old 03-30-2016, 10:28 PM
Dan_the_C5_Man
Dan_the_C5_Man's Avatar
DH
I was all prepared to send mine out, so I called them today - with shipping both ways, it would be around $240 - not cheap ($192 for the service, another $45'ish for shipping). I am less sure about it now..
Old 03-30-2016, 11:53 PM
MTPZ06
MTPZ06's Avatar
Not bad IMO. I would do it without hesitation if I was going in the direction of cam, Mamo MSD, NW TB, ported and milled heads, etc.
Quick Reply: [Z06] Tested my injectors
