[Z06] !help! disable/remove YAW sensor
ok i just did a auto swap on my c6z and every time i start to spin it goes into "active handling" which shuts the car off/down . is there anyway to disable this or trick the system? already unplugged the steering wheel sensor and pulled the abs fuses and it still kicks in and of course holding the button doesnt work. any idea or help thank you
Received 8,927 Likes
If you disconnected the steering sensor then the yaw sensor isn't doing anything since active handling is defeated by unplugging the steering sensor. Active Handling uses the steering sensor to determine whether or not to activate since it needs to know which way you are trying to point the car. If it doesn't get that input the EBCM shuts it off during the ABS self test the EBCM conducts as soon as you start the engine.
Disconnecting the Steering Sensor however does not defeat Traction Control. You still have to turn traction off by using the button on the console.
The lateral G/yaw sensor only provide a signals to the EBCM. They do not send signals to any other module in the car.
Now if you pulled the ABS fuses that means that ABS, Traction Control and Active Handling are all non operative because you cut off the electrical power to the EBCM which is the unit that controls those functions. Without electrical power the EBCM is dead and can't control the brake pressure modulator valve meaning it can't tell the BPMV to release or apply a brake and it can't send a message to the ECM telling it to reduce torque. Disconnecting the yaw sensor will do nothing since the EBCM is already dead.
That means your problem is somewhere else.
Bill
Active handling is part of the Anti Lock Brake System works and it is evident by some of your statements that you don't know how the system works.
Bill
Bill
When you pulled the ABS fuses you disabled ABS, TC and AH. Is that succinct enough.
ABS, TC and AH are all controlled by the Electronic Brake Control Module.
If you are describing your problem and what you have done correctly then the problem lies elsewhere in the car.
You may have an ECM problem or some sort of a misfire issue but with those fuses pulled the EBCM and all of the functions of the EBCM are not just disabled they are dead, dead, dead.
If you think AH is still doing something either you don't know how it works or you really haven't disconnected the steering sensor connector or pulled the fuses.
Bill
Who did the conversion and what transmission did you use?
What controller are you using for the transmission?
When you say shuts the car off/down, do you mean it completely turns the ignition off or do you mean it applies the brakes?
its a PSC controller, nah it just goes into active handling which wont let me move forward unless i let go of the gas and go again. for some reason it wont let me turn the active handling off when holding the button and i think its cause of the sensors not being plugged in for t56 and tire lights on from drag wheels
