[Z06] Trip to CO... Need 93 octane
Greeting! I live in KC where I can get 93 octane gas all day(BP). I'm wanting to go on a road trip to CO here in a few weeks but I'm having issues with finding 93 out there. I've been reading about mixing high octane stuff with 91 to make 93 but some of it seem a bit off. Can anyone give me good advice on how I can make it out there? Also, any good tuners/shops in Denver? Thanks!
milled heads .030" with Katech K501
I've read there's some 93 octane stations in the denver area, but the rest of the state is 91.
If you are not modded, you can use 81. The OM even indicates in a pinch you could run 87, just don't use the performance of the car. All I can get here is 91. I only mix in 100 when I can get it at track events to get the overall octane up to 93+, but that is running the engine 4-7K all the time.
Dan the man. Got it right buy Torco Accelerator and add half a quart per tank to go from 91 to 93 octane it's just that easy. I do it all the time here in Tulsa where Sinclair has a refinery withaa 117 octane stream but only sells 91 octane statewide .
Its all about dynamic compression, not static compression. At lower VE levels, octane is a non issue. If you part throttle drive, you'll never approach the knock threshold of the fuel. Peak tq rpm, at full throttle, is also peak ve...thats when the knock resistance is most utilized.
No issues at all running 91. Just fill up and enjoy. The higher elevation doesn't need 93. Also if you are worried, just don't beat on it. Car doesn't need crazy octane at part throttle.
If your car is tuned so aggressive that running 91 instead of 93 is going to cause an issue, find a new tuner.
additional item to watch for knock
the other item I've used as I use Torco to boost my octane is a Palmer Electronics Dashlogic unit that plugs into the OBDII port. I've been using Torco to have 93 octane and have never had the Dashlogic unit warn me that I'm seeing any knock.
It allows you to monitor the car for knock; so when you're using octane boosters. It helps ensure you're in the safe zone as it monitors the engine for ANY knock; and posts the info to your DIC/HUD.I've been using one for two years now and have never detected any knock, its cheap insurance if you go the route of using an octane booster. For the record. Torco is shipped with hazardous shipping included at a cost of 120/1.5 gallons, or just over $300 for 5 gallons.
Each quart contains enough booster to raise the octane from 91 to 93 for two 16 gallon tanks...although I always use the half quart to treat 13 gallons - and have a safety margin. Since I run a lab in my work life, I've used my empty cans to measure out half quarts ahead of time, as I recall it ends up being 360 grams/ half quart of Torco. While that sounds low, its due to the use of low lb/gallon aliphatic solvents as the MMT carrier (MMT is the manganese based booster).
However a word to the wise, MMT will invalidate your warranty; so if you've got an extended warranty - its not the way to go. Chevrolet mentions MMT in their warranty.
However it doesn't hurt the engine at all; as it was a organometallic compound originally developed by Ethyl Corporation to replace TEL (tetraethyl lead). Properly formulated, like Torco, MMT octane boosters have materials in then to help prevent any inline valve buildup in the valve seating area, as well as protection from valve seat recession.
My brother worked at Ethyl while MMT was developed as an Executive VP, so I have a complete understanding of the chemistry. Really good stuff when properly formulated as it is in Torco.
Torco even has a small amount of naphthalene in their formula (moth ***** are made from naphthalene)...which is a really old school trick that the government used in WW2 to ensure the octane levels of fuels used in the battlefield. (Gas chromatography and Mass Spec is your friend).
Torco does work great, but if he is just highway cruising through CO no need. Just enjoy the trip. Now if he is going to CO to do a race, I could see the concern, but unless he is ripping 4500+rpm and beating the hell out of the car, it probably wouldn't even care if it was 87 octane.
Thanks for the replys! I'll follow up when I get back.. hopefully without a speeding ticket. Driving across Kansas can get boring and my foot thends to get heavy.
I made the trip last year from STL. Don't be pissed when your 12,000 feet above sea level and your car feels like it's down 6 cylinders lol. I had good luck stopping at shell...but like everyone said 91 is all you can get. I recommend going down to Cannon City and taking hwy 50 up to Salida.
There's nothing like an LS7 - nothing that Chevy has ever built, although I'm pretty sure the new flat crank GT350R with an 8250 rpm redline would be even more fun...much closer to a Ferrari .
Dude, no offense if you call a 4500 rpm "ripping it" then you ought to have a coupe with a 6500 rpm redline. I love to shift at 5500- 6500, not WOT shift but rather continuous acceleration; until its opened up; with the occasional WOT pull to 6800 as I get on the highway. If you don't drive it and enjoy the powerband of the LS7 then why did you get one??
My car goes to 7500. It doesn't start making 1000+rwhp until 4500 so it isn't even any fun until then. As far as an ls7, I sold mine to a guy that dropped a valve twice, and did a nice LSX setup. I got a z06 for the drivetrain/aluminum frame, not the motor.
