C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] C6 Corvette ZR1 Mild2Wild Exhaust Controller - Our Best Price Ever!
Old 09-02-2015, 01:46 PM
RPI Designs
Platinum Supporting Vendor
RPI Designs's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16 -'17
Default C6 Corvette ZR1 Mild2Wild Exhaust Controller - Our Best Price Ever!
C6 Corvette Mild2Wild Exhaust Controller - Mild to Wild fits 2006-2013
FREE SHIPPING ON THIS ITEM
This Mild 2 Wild exhaust controller is Compatible with the all C6 Corvette Z06's, ZR1's Grand Sports, and on 2007+ Coupes and Convertibles with the Dual Mode Exhaust (NPP Option)
Imagine having the ability to turn your Corvette C6 Z06, Grand Sport, ZR1, and NPP exhaust from MILD (exhaust ports closed) to WILD (exhaust ports open) using you OEM Homelink (found on your visor) or via the supplied remote.
Mild2Wild (Mild to Wild) works with the All 2006 and up Z06's, Grand Sport with NPP, 427, ZR1 and all 2008, 2009, 2010, 2011, 2012, 2013 C6's (with the NPP bi-mode exhaust option)..
New Product.. Exhaust On Demand Imagine having the ability to turn your exhaust from MILD (exhaust ports closed) to WILD (exhaust ports open) using you OEM Homelink (found on your visor) or via the supplied remote. Also works with the new B&B fusion exhaust.
This revolutionary product lets you control your, 2006/2007/2008/2009/2010/2011/2012/2013 bi mode exhaust system on demand via a tiny wireless remote or the Homelink feature in your car . One of the coolest technologies is the “bi-mode” exhaust. Whisper quite up until 3500 RPM and then a wide open race car sound as the flaps located in the tips open. 2010-2011 C6 Corvettes must use the remote to control the valves.
The problem is the inability to control this feature. Up until now, the owner’s only choice was to pull the fuse or to install wiring, drill a hole for a switch to turn the quiet mode off (and these sell for $85). After spending $75,000, the last thing you would want to do is start running wires and drilling holes. Introducing the first and only wireless remote designed to give you full control over the exhaust.
This Mild2Wild exhaust control(Mild to Wild) is a patent pending product and requires no drilling or running wires through your car. It’s a simple 5 min simple plug and play installation that anyone can do. Once installed, you will have full control over the exhaust mode, via a simple ON/OFF remote wireless controller or your Homelink transmitter (simple programming required, instructions provided). Once the Homelink is programmed, you can just use that to work your exhaust. Actually, you will get two sleek ON/OFF wireless controls that can be mounted anywhere and will control the exhaust up to 50’ away.
The “OFF” mode gives you that race car sound 100% of the time. The “ON” mode works as the stock setting and is quiet to preset OEM 3,500 RPM . The switch can be used anytime the car is running, allowing you to show your friends what a cool exhaust you have as you can use the remote and open and close the flaps on demand. How cool to stand behind your car and demonstrate the exhaust, using the remote. The system can be removed in seconds and you will never know it was there. You will receive the professionally engineered plug and play wireless receiver, two miniature remotes (battries included) and the necessary homelink programing instructions.
Take full control of your NPP/Z06/ZR1 exhaust with the #1 selling MILD2WILD (Mild to Wild) wireless exhaust controller. Developed over 2 years ago, it quickly became the must have modification for any bi-modal exhaust equipped car. It’s Jay Leno’s and Scott Dixon’s (Indy 500 Winner) choice for their cars and has even been certified and used in many Corvette dealerships.
MILD2WILD installs in less than 3 minutes requires no cutting, splicing and is 100% reversible. The unit comes with two wireless micro FOBs that allow you to open the bi-mode exhaust at any time so you can enjoy that great sound anytime. You will be shocked at just how great your car will sound and with a press of the button it will set back to the OEM setting.
C6 Corvette MILD2WILD (Mild to Wild) remembers the last setting (shut off car with flaps open, starts with flaps open / shut with flaps closed, starts with flaps closed) and it also has a ZERO battery drain install.
In Stock Here: http://www.rpidesigns.com/shop/item.aspx?itemid=895
__________________
RPI DESIGNS, LLC. - C5/C6/C7 Corvette Parts
4000+ C5/C6/C7 Parts & accessories - Forum members get 10% off with SS2007 coupon at checkout
Like us on www.facebook.com/rpidesigns and you might win $100.
Our brand new C7 Corvette Z06 Style Side Skirts come painted in Carbon Flash Metallic, see them here!
email: rpi.designs.customerservice@gmail.com Web: www.rpidesigns.com
Old 09-23-2015, 10:24 AM
RPI Designs
Old 01-12-2016, 10:29 AM
RPI Designs
Thank you for the orders!
Old 02-03-2019, 01:41 PM
joshp14
joshp14's Avatar
I just bought my car and it has the mild2wild module by the fuse block but I did not get the keyless remotes to activate it. Do you sell just the remotes?
Old 02-05-2019, 09:08 AM
RPIDON
RPIDON's Avatar
Hi,
Unfortunately not, each switch will only work with the remotes that it was bought with.
Let me know if we can help you with anything else.
Thanks,
Chris
Old 03-17-2019, 12:31 AM
RedZ4me
RedZ4me's Avatar
No idea of where my instructions are - any link so I can program HomeLink? thanks
Old 03-18-2019, 09:18 AM
RPIDON
RPIDON's Avatar
Hi,
Here is a link where you can find instructions:
https://www.nakidparts.com/c6-corvet...-zr1-mild2wild
Let me know if you need anything else.
Thanks,
Chris
Old 03-30-2019, 11:50 AM
RPI Designs
Thank you for the orders! Use coupon code LANA5 to save 5% off your order!
Old 08-18-2019, 10:10 PM
RPIDON
RPIDON's Avatar
Thanks for checking us out!! Use Coupon Code RPICHRIS5 for Immediate Savings!!!
Old 01-20-2020, 10:46 AM
RPIDON
RPIDON's Avatar
These make a great addition to any C6 Corvette!
If you would like to visit our Online Catalog and view all of the C6 Corvette Parts
and Merchandise that we have available for sale, just click the link below…
Website Link:
RPI Designs’ C6 Corvette Online Catalog
Forum Members remember to use RPICHRIS5 at checkout for an Immediate Discount.
This Coupon Code is always Active!
To C6 Corvette ZR1 Mild2Wild Exhaust Controller - Our Best Price Ever!
Quick Reply: [ZR1] C6 Corvette ZR1 Mild2Wild Exhaust Controller - Our Best Price Ever!
