[Z06] GMPP stage 3 cam, will I have piston to valve clearance issues on a stock LS7?
#41
I second that recommendation...Ferrea F2042p exhaust valves would be an excellent choice. I would also recommend PSI 1515 springs with Ti retainers (BTR makes them for the 1515 spring) for your build.
#42
Correction, I went back and checked some old emails and I was one year off, the engine was actually bought in late 2007 so I must have the old exhaust valves then.
So the question is even more relevant now.
#43
Are these the correct retainers:
http://www.briantooleyracing.com/sr0...set-of-16.html
#44
That said, the consensus is that the exhaust valve manufacturer increased the inner-wall thickness in the later versions, which would naturally increase component durability. Katech's point is, "with properly machined heads, do you NEED the additional wall thickness"? Considering the relatively low cost to swap them out, it does make good sense to do so.
#45
Supporting Vendor
Received 1,012 Likes
I would not run the old style LS7 exhaust valves (the early design).
We cut a bunch of them up a few years ago and they had extreme inconsistencies in wall thickness from one side of the valve to the other.
If you want to run GM sodium exhaust valves go with the late model valves (late 08'+).
EVOVII_SWE:
Responded to your email with parts shipping quote to Sweden.
EVOVII_SWE:
#46
You have to appreciate that Katech had some level of involvement with the testing and development of the LS7 platform, so keep that in mind.
EVOVII_SWE:
EVOVII_SWE:
#47
Thanks for the suggestion, would you please motivate why I should do that? The springs and retainers that is.
As for the retainers, I would email BTR to ensure you have the proper ones for your application.
#48
Spintron testing has shown PSI beehives to have more control over the valvetrain at higher RPM's in LS7's. The PSI 1511 is a great spring and I run them in my C6Z, but its still on a stock cam. While the 1511's work well with aftermarket cams (Katech uses them in their builds), the 1515 spring was developed for the LS7 with a high lift cam. http://www.briantooleyracing.com/650...e-springs.html
#49
So, the engine is finally back together again with new valve guides and everything to support the cam
It will be mapped when temperatures starts to rise again after winter, very exited to see the results on the dyno and I hope I can live with the driveability of that cam.
A short clip of one of the first startups, it sure sounds nice to me but it depends on perspective, my girlfriend said "is it broken?"
#50
https://youtu.be/xacf0iphmWg
EVOVII_SWE (01-11-2017)
