[Z06] Class Action Against GM !!??
#422
Remains to be seen, but I wouldn't expect anything for the foreseeable future. You're unfortunately on your own for now.
#423
Add me to the list, all 16 valves were out of spec.
Car is bone stock down to the air filter, 17988 miles when it arrived to AHP to get repaired.
#424
But plenty of people are claiming that less than 1% have out of spec guides. MTPz06 is correct. Plus, as mileage and age goes up, the drop valve part would be surprising if <1%. Just in the people I know it is far far higher than that.
MTPZ06 (04-26-2018)
#428
It comes down to the definition of the term "failure". Has an engine with valve guides out of spec failed? I say, if the engine still runs normally and sounds normal, it has not failed.
How many engines have actually dropped a valve? It is a very difficult subject with incomplete data. And it is even more difficult because so many people have modified their heads, which hopefully drastically reduces the failure rate.
#430
In 2003 when BMW E46 M3s had blown 150 engines in the US, they did a recall on all of them to replace the main bearings under warranty. That was probably less than 1% of all the E46 M3s sold at that time.
From posts here, there have certainly been hundreds of blown engines due to dropped valves in the LS7 for the roughly 30,000 produced. At least one fellow has witnessed 8 blown engines and at least two forum members have had two replacement engines installed.
#432
Seriously, though, there is no wrong answer to this. Where would you put the threshold for a recall?
#433
I would love for them to fix my engine, as long as they do it right. I have to say, 300 is still only 1%. But I have no evidence of that many. If I have a 99% probability that I won't have a failure, I will probably just take my chances.
I expect they will sell cars that have heads in spec new and are still in spec during the warranty period. The high majority of heads of forum members that have been measured have been beyond the wear spec that GM says is bad. My engine had 14 of 16 valve guides out of spec at 46K miles, while the car was still under warranty and the LS7 was still stock with no mods.
BMW recalled and fixed ALL the E46 engines because of the bearing problem, not just to ones that failed. GM bet the heads wouldn't fail and had no problem making customers foot the bill (screw them) to repair out of spec heads as long as they didn't fail in the warranty peried.
#434
THE LAWYERS WILL GET IT ALL......Don't think any C6 owners will get a dime...well maybe a dime.
#435
I'm fine with that...as long as GM cuts a check (which they wont really feel), and they get the corresponding bad publicity through all major news outlets. Which again, wont amount to much other than some personal satisfaction...I'm cool with that.
#436
Good luck!
#438
I think their only obligation is if the engine fails during the warranty period. They could do more for their customers, though. However, I bet many, many engines out there are running fine (of all types) that have something out of tolerance after 30,000 miles.
So no one is willing to say what they think is a reasonable failure rate threshold for recall? I'm just looking for opinions.
#439
Again though...you and I define "failure" much differently.
#440
A wide-spread and well documented manufacturing defect (guide to seat non-concentricity) should most certainly be grounds for a recall. The problem with that, until they rectify the manufacturing defect, there's no point in warrantying non-concentric heads with a new set of highlier than likely non-concentric heads. I'll stick with my AHP MS90 heads.
What do you think would be a good threshold for recall for engines that fail (drop a valve)? I'm looking for a percentage of the total.
