C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Need help...
Old 12-16-2015, 09:02 PM
cyber09Z
cyber09Z's Avatar
Default Need help...
I have 09 Z06. I hurt my motor so I pulled it myself. Had it built and now reinstalled. Only problem is my nav and radio dont work. The screen is just black. But if u press the bottom button in the middle it opens and if u press it again it closes. But nothing else. I check fuse by the passenger floor board. I disconnected battery for 15 minutes and tried again nothing? Please help
Old 12-17-2015, 10:19 AM
Landru
Landru's Avatar
Received 1,045 Likes on 819 Posts
Must trace any/all wiring you'd disconnected for the pull, especially connectors. Something's either not connected a'tall or improperly connecting within a connector, possibly a wire pulled loose from a connector during reinstallation?
Sorry, only thing I can think of.
Try posting this in 'Technical' & 'Audio".
More knowledgeable members will/can read it & respond with more ideas. G/L, hopefully it's simple.
Old 12-17-2015, 02:39 PM
cyber09Z
cyber09Z's Avatar
I fixed it
Old 12-17-2015, 03:23 PM
Dan_the_C5_Man
Dan_the_C5_Man's Avatar
Good forum Karma (and etiquette) to post what the fix was (for future members with the same issue).
Care to share?
Old 12-17-2015, 09:24 PM
cyber09Z
cyber09Z's Avatar
I disconnected the negative battery cable. Then disconnected the power battery cable . Waited 15 minutes and reconnected the battery cables and the radio and navigation started to work normally. .. thanks u guys
Old 12-18-2015, 10:25 AM
Landru
Landru's Avatar
I disconnected the negative battery cable. Then disconnected the power battery cable . Waited 15 minutes and reconnected the battery cables and the radio and navigation started to work normally...
So a simple reboot did the trick?
Figures, usually first thing members recommend myself included.
I'd hoped it was simple & it doesn't get any simpler.
Old 12-20-2015, 02:26 PM
cyber09Z
cyber09Z's Avatar
Yup thanks for ur help
To Need help...
Quick Reply: [Z06] Need help...
