C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Help with black plastic PCV lines on top of engine
Old 12-30-2015, 06:46 AM
acscogginjr
acscogginjr's Avatar
St. Jude Donor '12
Default Help with black plastic PCV lines on top of engine
I broke both of the hard black plastic PCV lines that run from the passenger firewall oil canister to the drivers side behind the intake manifold and down the intake manifold on passenger side to just below the throttle body.
What's the best way to replace these? Replace with OEM or some guys have added rubber and/or braided hoses?
Thanks, Austin
Old 12-30-2015, 08:42 AM
double06
double06's Avatar
Default I replaced mine with rubber
ran the drivers side one behind manifold so you do not see it.
Old 12-30-2015, 10:55 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Either way works. Can replace with rubber line, or get new OEM ones.
Old 12-30-2015, 03:14 PM
acscogginjr
St. Jude Donor '12
Thanks to Matt at 21st Century Muscle Cars for hooking me up with a set!
Austin
To Help with black plastic PCV lines on top of engine
Quick Reply: [Z06] Help with black plastic PCV lines on top of engine
