[Z06] Window sticker
Cruising
I just recently ordered both a build sheet and window sticker for my 2013 427. It does take a whole 2-3 weeks for it to get out to you, but they are nearly indiscernible from the originals, save for the scratches and creases.
As an added bonus, the window sticker is even a full color version, so it's 100% identical to the original. I couldn't be happier with mine!
Cruising
If you only want the build sheet, its about $60 or so with shipping. However, if you want the window sticker, for whatever reason they require you to buy a build sheet as well and it will run you around $110-125. It seems kinda stupid that they require you to buy a build sheet as well, but I'm sure there is a reason.
Heck, last I remembered hearing a year or so ago, they initially had stopped ALL window sticker reprints. Then, mysteriously, when they offered again, it required the build sheet as well. A legal issue possibly?
