[Z06] Z06 front brake rotor replacement part number
I am about to replace front rotors on my 2006 Z06. I found some on ebay at a very good price but the part number seems different than what I originally researched . I thought there are right and left rotors with Gm part numbers 19121788 left and 19121789 right. However I have found rotors on line that appear to be the same for right and left with part number 19121787. These are made by delco and also carry other part numbers, Gm22812086 and 177-1126.
Can anyone look these numbers up to tell me if I can use these rotors for both sides? Thanks!
Here's the information I have. I believe the GM and ACDelco are the same parts but I don't know that for sure. I have used both on my car and I could not tell the difference.
GM part 22812086 from www.cultragfactoryparts.com (same number for left and right).
http://www.cultragfactoryparts.com/c...&position=left
http://www.cultragfactoryparts.com/c...position=right
ACDelco part number 177-1126 also fits your car (same number for left and right).
ACDELCO GM ORIGINAL EQUIPMENT
Front Disc Brake Rotor
Part Number: 177-1126
Product Notes: Disc Brake Rotor
Front ; Hvy Duty Antilock Brakes(J56) ; Z06 ; 2 Per Veh
Both sides use the same rotor even though they are directionally cast for cooling. (Ridiculous, I know). Look at some DBA Rotors as another cost effective option.
Amazon has them also. ACDelco 177-1126 GM Original Equipment Front Disc Brake Rotor
SteveDoten@ARH (06-06-2016)
I don't know if they still do the same thing but before it was a shocker once you got your part to the check out and then saw the price for shipping. It was a low price for the part and then way over priced shipping.
Good luck!
Good luck!
I have connections with price at cost up here... OEM fronts $75 CDN. each for me!
Premium Supporting Vendor
Amazon.com: ACDelco 177-1126 GM Original Equipment Front Disc Brake Rotor: Automotive
