[Z06] New Build Complete; Disappointing Dyno Numbers...BUT
New Build; Disappointing Dyno on "PAPER"...HOWEVER
With the intent in mind to increase the durability, drive ability and overall street, track performance I changed up my original combo from a LPE 660hp built car to the following.
Hutter built short block with Mahle forged pistons with 1mm,1mm,1.5 rings (Rebuilt Due to COMP TRUNION FAILURE) with only 6400 miles on it.
Katech Blue oil pump with modified pan.
Advanced Induction 280cc heads
Stock GM rockers
Tony Mamo spec'd Mild 240/252 cam
Johnson short travel lifters with pressure feed oiling
Manton pushrods custom lengths
Tony Mamo MSD ported and shaved manifold
NW 102 TB
Bosch Injectors
Mighty Mouse PCV Catch can.
Halltech 103
AR headers and Corsa exhaust
RPM level IV transmission
Twin Disc Clutch
RPM rear end with 3.73 gears.
The car runs ALOT stronger vs the LPE 660hp package which had the larger 243/259 .700" cam. The driveability is great very smooth above 1600 rpms NO surging. Have only put 200 easy miles on it so far but the seat of the pants feel is unreal. BUT the dyno numbers are not doing this package justice. BUT again, when I picked the car up from Hutter's dyno shop his first question was what is your setup exactly?? Because that is the highest Dyno numbers they have seen from a street driven Zo6 with LS7. He also said the next higher car Dyno'd at 582hp and runs 9's. He said to compare with Dynojet numbers I would fall between 620-630 HP. SO, with that info and how the car drives I am very happy with the setup. SHOUT OUT TO TONY MAMO, PHIL at ADVANCED INDUCTION AND BRIAN TOOLEY FOR HELPING ME ALONG THE WAY!!
Stock GM rockers
NW 102 TB
Bosch Injectors
Halltech 103
Twin Disc Clutch
Received 3,043 Likes
St. Jude Donor '05
Screw dyno # run that betch down the track sounds like you got a rocket on your hands.
Dyno question
What you need to ask him is what does a totally stock C6 Z06 do on their dyno and then you can figure out the real delta and compare apples to apples.
Congrats on the results
I think he is more disappointed its a stingy dyno and he doesn't get to go home with a big number on an 8 X 11 piece of paper.
We all like to see the big numbers....its just part of the hobby.....most important thing is how it runs and how awesome the G forces flatten you in your seat!
Enjoy it.....maybe roll on a local DynoJet at some point to get a number a little more representative!
Regards,
Tony
PS.....The manifold I helped you with looks great but your crazy for not running my fitted red valve covers on there....that's the finishing touch on the under hood aesthetics! (especially with your red body color!)
__________________
Please take the time to also visit my website at www.MamoMotorsports.com
Todd, car looks sweet!!
Regards,
Tony
Regards,
Tony
Regards,
Tony
Regards,
Tony
Regards,
Tony
Regards,
Tony
Not disappointed with the results at all, this car is absolutely amazing to drive and the power is incredible, extremely smooth!! Just wanted to post a nice graph!! Proof will be when I take it to the track..
Just how this particular Dyno provided the feedback on paper. Alot of guys are posting Dynojet numbers 600-630hp. My car "appears" weak on paper, but my point is its not! Like I said in my post a car out of Hutter Dyno'd at 582HP and runs in the 9's with a six speed. My car is only down 17HP from that particular car and that car had 12:1 CR and Solid Roller cam. Sorry for the confusion.
